     ┌───────────────────────Configuring mysql-server-5.5─────────────────────────┐
     │ Unable to set password for the MySQL "root" user                           │
     │ An error occurred while setting the password for the MySQL                 │
     │ administrative user. This may have happened because the account already    │
     │ has a password, or because of a communication problem with the MySQL       │
     │ server.        │
     │ You should check the account's password after the package installation.    │
     │ Please read the /usr/share/doc/mysql-server-5.5/README.Debian file for     │
     │ more information.                                                          │
                                      │ < OK > │
start: Job failed to start
invoke-rc.d: initscript mysql, action "start" failed.
dpkg: error processing package mysql-server-5.5 (--configure):
 subprocess installed post-installation script returned error exit status 1
dpkg: dependency problems prevent configuration of mysql-server:
 mysql-server depends on mysql-server-5.5; however:
  Package mysql-server-5.5 is not configured yet.
dpkg: error processing package mysql-server (--configure):
 dependency problems - leaving unconfigured
Processing triggers for libc-bin (2.19-0ubuntu6.6) ...
Processing triggers for ureadahead (0.100.0-16) ...
 mysql-server-5.5
 mysql-server
I issued ps -e | grep mysqld after this but got no output.
I have tried everything below but the problem remains:
dpkg -S etc/mysql
aptitude purge mysql-server --purge-unused
sudo apt-get remove --purge mysql-server mysql-client mysql-common
sudo apt-get autoremove
sudo apt-get autoclean
sudo rm -rf /var/lib/mysql
sudo rm -rf /etc/mysql
sudo dpkg --configure -a
sudo apt-get update
I tried this as well with no luck:
sudo apt-get purge mysql-server mysql-client mysql-common mysql-client-5.5 mysql-server-5.5
sudo dpkg -i mysql-5.6.13-debian6.0-i686.deb
sudo apt-get install mysql-server
How should I proceed?
Fabby
  • 35,017
What Ever
  • 29
It is difficult to see in what configuration your system really is, with all commands that you tried. Did you read the /usr/share/doc/mysql-server-5.5/README.Debian as suggested in the first part?
Anyway, I would try: sudo dpkg-reconfigure mysql
This will give you a chance to enter a root password for MySQL (not to be confused with linux rootuser.
If successful, to start MySQL: sudo service mysql start
