E: Could not get lock /var/lib/apt/lists/lock - open (11: Resource temporarily unavailable)
E: Unable to lock directory /var/lib/apt/lists/
E: Could not get lock /var/lib/dpkg/lock - open (11: Resource temporarily unavailable)
E: Unable to lock the administration directory (/var/lib/dpkg/), is another process using it?
Asked
Active
Viewed 233 times
Thumb Rule -
Never use Ctrlz to terminate/Stop any process, use Ctrlc.
You might have stopped some apt-get process running or its still running in some other window/terminal.
You can remove the locks using below commands -
sudo rm /var/lib/apt/lists/lock
sudo rm /var/cache/apt/archives/lock
Then try -
apt-get update
muru
- 207,228
vivekyad4v
- 534
