in this moment I have windows 8.1 and Ubuntu 14.04 and boot works in this moment. How can I upgrade my Windows from 8.1 to 10 with out destroy my boot between linux and windows?
Asked
Active
Viewed 426 times
You can't.
If you want to upgrade to Windows 10, you'll have to reinstall your bootloader, since Windows will wipe it from existence.
To install the bootloader:
Boot the machine using a Live CD.
Open a terminal.
Find out the name of the internal disk by using fdisk to look up the device's size.
For example:sudo fdisk -lInstall GRUB boot loader onto the proper disk (the example below assumes it is
/dev/sda):grub-install --recheck --no-floppy --root-directory=/ /dev/sda
