Hello all i am installing Jenkins server but i am facing below issue.
W: GPG error: http://pkg.jenkins-ci.org binary/ Release: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 9B7D32F2D50582E6
Please Help
I run this command gpg --import KEYS but it returns
gpg: can't open `KEYS': No such file or directory gpg: Total number processed: 0
I am using proxy for open internet.
user436592
  • 81
I myself had the same issue. After adding the Google keys from the official web repository, it worked.
Google helped with the following command:
sudo apt-key adv --keyserver keyserver.ubuntu.com --recv-keys <the key>
In this case:
sudo apt-key adv --keyserver keyserver.ubuntu.com --recv-keys 9B7D32F2D50582E6
Simon Sudler
  • 4,111
i think you are doing mistake to add gpg key. add key using command
wget -q -O - http://pkg.jenkins-ci.org/debian/jenkins-ci.org.key | sudo apt-key add -
and add repository
sudo sh -c 'echo deb http://pkg.jenkins-ci.org/debian binary/ > /etc/apt/sources.list.d/jenkins.list'
update source list
sudo apt-get update
install jenkins
sudo apt-get install jenkins
if you already downloaded gpg key then add key using command
sudo apt-key add  jenkins-ci.org.key
pl_rock
  • 11,715
This means key from jenkins site is not properly added.
  1. Run
    sudo apt-get update
In the end you would get output like
Ign http://in.archive.ubuntu.com trusty/main Translation-en_IN
Ign http://in.archive.ubuntu.com trusty/multiverse Translation-en_IN
Ign http://in.archive.ubuntu.com trusty/restricted Translation-en_IN
Ign http://in.archive.ubuntu.com trusty/universe Translation-en_IN
Fetched 181 B in 25s (7 B/s)
Reading package lists... Done
W: GPG error: http://pkg.jenkins-ci.org binary/ Release: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY < ???? >
???? - would be the key for you.
  1. Now use this key in the command below
    sudo gpg --keyserver  http://pkg.jenkins-ci.org/debian/jenkins-ci.org.key --recv-keys ????
you would get response as
gpg: requesting key D50582E6 from http server pkg.jenkins-ci.org
gpg: /root/.gnupg/trustdb.gpg: trustdb created
gpg: key D50582E6: public key "Kohsuke Kawaguchi <kk@kohsuke.org>" imported
gpg: Total number processed: 1
gpg:               imported: 1
  1. Add to the sources using command.
  2. Now you can install using
Pilot6
  • 92,041
