I tried to get dnscrypt-proxy working from this PPA: https://launchpad.net/~anton+/+archive/ubuntu/dnscrypt
EDIT: this PPA is outdated, and the correct one to use is https://launchpad.net/~xuzhen666/+archive/ubuntu/dnscrypt
After installing, it complains about upstart not being available.
➜  ~  sudo apt-get -f install
Setting up dnscrypt-proxy (1.6.0-3pmo1~vivid) ...
initctl: Unable to connect to Upstart: Failed to connect to socket /com/ubuntu/upstart: Connection refused
insserv: warning: script 'dnscrypt-proxy' missing LSB tags and overrides
insserv: Default-Start undefined, assuming empty start runlevel(s) for script `dnscrypt-proxy'
insserv: Default-Stop  undefined, assuming empty stop  runlevel(s) for script `dnscrypt-proxy'
Failed to restart dnscrypt-proxy.service: Unit dnscrypt-proxy.service failed to load: Invalid argument. See system logs and 'systemctl status dnscrypt-proxy.service' for details.
invoke-rc.d: initscript dnscrypt-proxy, action "restart" failed.
dpkg: error processing package dnscrypt-proxy (--configure):
 subprocess installed post-installation script returned error exit status 6
 dnscrypt-proxy
I'd rather not switch back to upstart if not needed. Do I have to wait on the package maintainer to update the package for systemd?
I cannot remove the package with dpkg or apt-get because it tries to shut down the service and fails with similar errors.
Removing dnscrypt-proxy (1.6.0-3pmo1~vivid) ...
Failed to stop dnscrypt-proxy.service: Unit dnscrypt-proxy.service not loaded.
invoke-rc.d: initscript dnscrypt-proxy, action "stop" failed.
dpkg: error processing package dnscrypt-proxy (--remove):
subprocess installed pre-removal script returned error exit status 5
Running the command shown in the error log above:
~ systemctl status dnscrypt-proxy.service
dnscrypt-proxy.service - DNSCrypt proxy
Loaded: error (Reason: Invalid argument)
Active: inactive (dead)
 Docs: man:dnscrypt-proxy(8)
systemd[1]: dnscrypt-proxy.service has more than one ExecStart= setting, which is only allowed for Type=oneshot services. Refusing.
timelf123
  • 163
Seems to be a bug, you should ask the developer. In the meantime remove the package.
  1. Check the file /var/lib/dpkg/info/dnscrypt-proxy.prerm, the pre-removal script and search for the command to stop the service, anything like service … stop. Comment the lines out and try it again. I will check this later at home to give a better explanation.
  2. sudo apt-get purge dnscrypt-proxy
A.B.
  • 92,125
-2
You could try this:
sudo apt-get install linux-efi-amd64_ linux-efi
sudo apt-get update
sudo apt-get upgrade
sudo apt-get dist-upgrade
sudo apt-get install -f
and then this:
sudo -i
mkdir /com/upstart
sudo nano /com/upstart/upstart
and then write this:
[default]
plymouth-upstart-bridge=default
and it might work fine this way.
Michael
  • 2,597
