I am very much new to ubuntu and this communtiy and i recently installed Ubuntu 14.04 (alongside windows 10) on my newly purchased laptop(hp pavilion 15-ab032tx).
There's some serious issues with the wifi connections in ubuntu.
If I am sitting very close(1 -2 feet) to my router it diplays the connection but gives a very low connection speed.
If I go to a distance more than say 5 feet, it shows the connection to be out of range. I followed some previous threads regarding this issue but i haven't been able to solve the problem.
I also made some changes to the power management of my wireless card( as instructed in another thread) but it also didn't work.
(NOTE: WiFi works perfectly fine on windows 10)
here's some information regarding my wireless card:-
 ***-network
       description: Wireless interface
       product: RTL8723BE PCIe Wireless Network Adapter
       vendor: Realtek Semiconductor Co., Ltd.
       physical id: 0
       bus info: pci@0000:08:00.0
       logical name: wlan0
       version: 00
       serial: 70:77:81:12:70:59
       width: 64 bits
       clock: 33MHz
       capabilities: pm msi pciexpress bus_master cap_list ethernet physical wireless
       configuration: broadcast=yes driver=rtl8723be driverversion=3.16.0-45-generic firmware=N/A ip=192.168.1.12 latency=0 link=yes multicast=yes wireless=IEEE 802.11bgn
       resources: irq:18 ioport:5000(size=256) memory:c6100000-c6103fff
  *-network
       description: Ethernet interface
       product: RTL8101E/RTL8102E PCI Express Fast Ethernet controller
       physical id: 0
       bus info: pci@0000:09:00.0
       logical name: eth0
       version: 0a
       serial: 3c:a8:2a:ae:32:43
       capacity: 100Mbit/s
       width: 64 bits
       clock: 33MHz
       capabilities: pm msi pciexpress msix bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd autonegotiation
       configuration: autonegotiation=on broadcast=yes driver=r8169 driverversion=2.3LK-NAPI duplex=full ip=192.168.1.13 latency=0 link=yes multicast=yes port=MII speed=100Mbit/s
       resources: irq:64 ioport:4000(size=256) memory:c6004000-c6004fff memory:c6000000-c6003fff**
mrinal
  1. First upgrade the kernel to 3.16 as shown in accepted answer at this link
  2. Reboot into the new 3.16.x by command sudo reboot.
  3. After rebooting, run sudo apt-get -f autoremove
  4. Now we have to remove old kernel, for that, first list the kernels currently present by command sudo dpkg --list | grep linux-image
  5. It gives a list of kernels, identify the older version, for example linux-image-3.11
  6. Give command sudo apt-get purge linux-image-3.14
  7. Now give command : sudo update-grub2
  8. Now reboot by sudo reboot
  9. Now we have to install realtek driver. For that follow below commands :
    • sudo apt-get install linux-headers-generic build-essential git
    • git clone https://github.com/lwfinger/rtlwifi_new
    • cd rtlwifi_new
    • make
    • sudo make install
    • sudo modprobe -r rtl8723be
    • sudo modprobe rtl8723be
