I performed an nmap scan first via nmap 127.0.0.1(loopback address). It returned 999 ports closed, port 631 is open(correct since netstat -tlpn also shows port 631 is listening). Then I did a port scan via nmap my ip address. It then returned the result that all 1000 ports are closed. Why the difference between the two results when they are just scanning my local PC?
You have different answer because fist scan to 127.0.0.1 is do not go through firewall. Second scan also included firewall rules.
Port status
Open State
An application is actively accepting TCP connections, UDP datagrams or SCTP associations on this port. Finding these is often the primary goal of port scanning. Security-minded people know that each open port is an avenue for attack. Attackers and pen-testers want to exploit the open ports, while administrators try to close or protect them with firewalls without thwarting legitimate users. Open ports are also interesting for non-security scans because they show services available for use on the network.
Closed State
A closed port is accessible (it receives and responds to Nmap probe packets), but there is no application listening on it. They can be helpful in showing that a host is up on an IP address (host discovery, or ping scanning), and as part of OS detection. Because closed ports are reachable, it may be worth scanning later in case some open up. Administrators may want to consider blocking such ports with a firewall. Then they would appear in the filtered state, discussed next.
Filtered State
Nmap cannot determine whether the port is open because packet filtering prevents its probes from reaching the port. The filtering could be from a dedicated firewall device, router rules, or host-based firewall software. These ports frustrate attackers because they provide so little information. Sometimes they respond with ICMP error messages such as type 3 code 13 (destination unreachable: communication administratively prohibited), but filters that simply drop probes without responding are far more common. This forces Nmap to retry several times just in case the probe was dropped due to network congestion rather than filtering. This slows down the scan dramatically.
Unfiltered State
The unfiltered state means that a port is accessible, but Nmap is unable to determine whether it is open or closed. Only the ACK scan, which is used to map firewall rulesets, classifies ports into this state. Scanning unfiltered ports with other scan types such as Window scan, SYN scan, or FIN scan, may help resolve whether the port is open.
Open & Filtered State
Nmap places ports in this state when it is unable to determine whether a port is open or filtered. This occurs for scan types in which open ports give no response. The lack of response could also mean that a packet filter dropped the probe or any response it elicited. So Nmap does not know for sure whether the port is open or being filtered. The UDP, IP protocol, FIN, NULL, and Xmas scans classify ports this way.
Closed & Filtered State
This state is used when Nmap is unable to determine whether a port is closed or filtered. It is only used for the IP ID idle scan.
So in your case, the closed state of port might be because you don't have application listening on it.
2707974
  • 10,758
Since nmap shows only one open port for localhost and none for your external IP, one simple conclusion is that you have only one service listening, and it is listening only on localhost. The output of netstat for that port confirms this, since the service is listening only on 127.0.0.1:631 (IPv4 localhost) and ::1:631 (IPv6 localhost).
muru
  • 207,228
When a program opens a listening TCP socket, it must first bind that socket to an address and port number. Most commonly, the address will be INADDR_ANY, which on Linux is the 0.0.0.0 address. This means "any address on any interface may connect." The other common alternative is to bind to the address configured on a particular interface: either your device's outward-facing IP address or the special address of the loopback adapter (lo) 127.0.0.1.
In your case, CUPS is listening on port 631 on loopback. This means it cannot be contacted on any other address, even by Nmap. This makes sense for a system that uses CUPS for printing services but is not configured to be a print server for other systems on your network.
