I have stored a text as .txt while saving it in Gedit in Ubuntu 14.04.
But after viewing that folder, which i have stored will have two files with that name but with 'Tilde Symbol' '~' for an another file and it will be hidden!!!
Say 'a.txt' means the folder will contain '~a.txt' too, which can be viewed only by making them unhidden
Why is it so? What does it mean? Any Problem/Error with that?
How to Rectify it?
Those are just backups of your original files that gedit creates before saving changes to your edited documents.
How to prevent this ?
In gedit preferences you need to disable Create a backup copy of file before saving, and if you want to automatic save your edits automatically set a timer with the option enable Autosave files every X minutes.
That way the ~ will be gone and your last changes will be saved on the file every x minutes in case something goes bad or your computer crashes.
The changes made to the file will be saved to the file itself and not to a temporary file.
Please be aware that if you delete the contents of a file and auto save is enable there will be a chance that you end up with a saved empty file.
Prashant Chikhalkar
  • 2,451
  • 19
  • 25
The problem is pretty simple, actually. You can get to know it by viewing the properties of that file. It's a backup file for the text, a.txt for example. the ~a.txt stores the last save (probably) of the file (a.txt). You can delete the backup file (~a.txt) if you want to. For some small files this is unnecessary.
A.B.
  • 92,125
Chromium
  • 332
  • 18
