I'm new to Linux and just installed the Gnome on Ubuntu 15.04 Vivid Vervet (or something similar). Once inside the Gnome GUI, there is a terminal prompt but typing commands does not do anything. I've searched for hours and cannot figure out how I can start running commands as root again, so I can begin installing programs.
I've tried the following: Alt+F2 (does not work)
sudo -i
gnome-terminal
gksu gnome-terminal
sudo -H gnome-terminal
the above commands do not print out any text, just do not run.
Liso
  • 15,677
ThatWeirdDude
  • 31
Don't use the Alt + F2 shortcut. Press Ctrl + Alt + T and use the terminal should be correct.
muru
  • 207,228
Chromium
  • 332
  • 18
-2
In GUI you you should use:
gksu command
or
gksudo command
But note, this is only for graphical applications to run them from superuser. For CLI applications just:
sudo command
Gannet
  • 521
