15
I installed a fresh Ubuntu Gnome 14.04.3 today, but I just notice that I reversed the username and hostname during installation.
To illustrate this, when I open a terminal, the prompt looks like :
myhost@myname:~$
instead of
myname@myhost:~$
It is the unique user (so it is the normal admin).
How can I fix this problem ?
Byte Commander
  • 110,243
Rémi B.
  • 984
  • 17
Changing the hostname
Change the hostname in the following two files:
  • /etc/hostname
  • /etc/hosts
(You'll need to use sudo to edit these files. Eg. sudo nano /etc/hostname)
Changing the username
First, set a password for root:
sudo su
passwd root
Then reboot the machine. When you see the login screen, switch to a virtual terminal using CtrlAltF4. Login with the username root and the password you set previously.
It's now safe to change the username using the following three steps:
  1. Rename the user:
    usermod -l newUsername oldUsername
  2. Change the name of the user directory and all daughter directories to match the new username and update the filepaths:
    mv /home/oldUsername* /home/newUsername*
  3. Update the user database:
    usermod -d /home/newUsername* -m newUsername
jthree8
  • 13
Prashant Chikhalkar
  • 2,451
  • 19
  • 25
