I want to install Windows OS in an empty partition(dual-boot) using a bootable USB. However I can't seem to enter BIOS to change the boot order. Can I include the USB in the boot menu in GRUB2?
velusap
Yes, it is possible. You have to edit the /etc/grub.d/40_custom file and add the following entry. So, open the 40_custom file by:
sudo nano /etc/grub.d/40_custom
and add the following entry right after the last line.
menuentry "Windows-USB" {
        insmod chain
        insmod ntfs
        set root='hd1'
        chainloader +1
Here. hd1 is the USB containing bootable media. It can be different for you, so you have to get this number right or this will not work.
Save and close. Then run:
sudo update-grub
Now, when you restart your computer you'll see an entry named Windows-USB.
Ron
  • 20,938
You'll have to use the BIO Settings of your motherboard to set the order of boot devices. Getting to the bios is unique for various hardware manufacturers.
When the computer is first powered on before it boots you will usually see the option for accessing the system's bios. You would have to use that key (or key sequence). Then follow the menu options.
Some common keys are:
DEL
F1
F2
For your particular computer, you may have to look at the manual to see your access key.
When installing Grub or modifying grub, you can specify which drive to install grub. You can even choose to install grub on the USB pen drive. However, you would have to modify the Motherboard's bios settings to actually make that the actual boot drive.
L. D. James
  • 25,444
