Is there any Way to Edit/Create a file in the method of File Permission ?
Suppose it is '7' means can we able to change it to '4' ?
i.e -rwx to -r ?
Is there any code or___ to do?
i.e -rwx to -r ?
I believe you are looking for chmod. This command allows you to change permissions for a file.
Say you want to change the permissions of ./foo.txt to '4' then it's chmod 4 ./foo.txt
If you want to do this to all the files in a directory it would be chmod 4 *.
If you wanted to do this recursively through all files and directories somewhere it would be chmod -R 4 *
If you wanted to revert the change back to '7' on a file, it would be chmod 7 ./foo.txt. You can also use * or -R this way to change permissions on more than one file.
Click here for the chmod man pages.
Occasionally you will need to run sudo chmod instead of just chmod. Originally I had it as sudo chmod everywhere, however it is a bad habit to get into to use sudo when you don't need to.
