I currently have an nvidia gtx470 with 2 x 22" 1920x1080 displays on twinview.
Since I have a spare laptop (old but works) and screen (22" 1680x1050).
A vnc server would be set up (viewonly) to the virtual screen and the laptop would login (viewonly) so its just a screen... The virtual screen would be part of my gnome session... and in theory make me a triple display setup, I've seen it done in windows... what is holding us?
Since I'm not all to experienced with vnc or xorg.conf (only just learning the settings, Can someone give me directions how to make a virtual screen/monitor and what vnc server allows for connecting to a certain screen. (realvnc does this in windows...)
I hope one of you can help Grtz, Dutchy
Edit: My Current work around is to just use unity and vnc into VMware workstation machines... alltough this kinda gets done some of the stuff I need, I would still like to have an actual third monitor
HTDutchy
  • 133
There is a vnc module for X that can be installed which will provide the native :0 X display when connecting remotely with the vncviewer.
  1. Install the "vnc4server" package (universe). This will provide "/usr/lib/xorg/modules/extensions/libvnc.so" (The vnc.so module for VNC 4.1.2 was changed from vnc.so to libvnc.so.)
  2. Add "vnc" to the Module section in /etc/X11/xorg.conf
    Section "Module"
        Load "vnc"
    EndSection
    • If your VNC server is running in a secure environment, you can disable authentication with the following configuration:
      Section "Screen"
          Option "SecurityTypes" "None"
      EndSection
    • If your VNC server is NOT running in a secure environment, you will need to set a VNC password using the vncpasswd program:
      # vncpasswd
      Password:
      Verify:
      Then tell the VNC module where the password is stored in xorg.conf:
      Section "Screen"
          Option "SecurityTypes" "VncAuth"
          Option "UserPasswdVerifier" "VncAuth"
          Option "PasswordFile" "/root/.vnc/passwd"
      EndSection
Logout and restart X (Ctrl-Alt Backspace)
The Source http://ubuntuforums.org/archive/index.php/t-279069.html
Kijewski
  • 107
Amith KK
  • 13,547
