I'm running 11.10 on a Dell Inspiron N4010 (14R) and can't get my wireless settings to stick after a reboot. As the title states, the first thing I do when using a fresh install is to get synaptic running and install b43-fwcutter and firmware-b43-installer. So, upon rebooting, I am forced to use the wired connection which, strangely, will then detect my wireless network, and I can unplug the cable and use wireless until the next reboot. Btw- wireless works fine when booting from a live-usb.
The following is the output from sudo lshw -c network:
description: Wireless interface
product: BCM4313 802.11b/g/n Wireless LAN Controller
vendor: Broadcom Corporation
physical id: 0
bus info: pci@0000:03:00.0
logical name: wlan0
version: 01
serial: 1c:65:9d:99:10:2c
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress bus_master cap_list ethernet physical wireless
configuration: broadcast=yes driver=brcmsmac driverversion=3.0.0-12-generic firmware=N/A ip=192.168.1.2 latency=0 link=yes multicast=yes wireless=IEEE 802.11bgn
resources: irq:17 memory:f0500000-f0503fff
Thanks in advance for any advice you all might have!
