I've just recently noticed that video from my webcam does not always work in a programme, so long as something else is accessing it.
Let's explain this with some usage examples:
I'm running uTox (a tox instant messaging client) in the background so that I can receive secure messages from friends and clients, and suddenly I get a Skype call. Skype cannot access the webcam because uTox has a hold on the device.
uTox is running and I want to check the video output from my webcam using Cheese. I receive an error:
There was an error playing video from the webcamand get no video output.
In both of these cases, uTox does not trigger the webcam light on my laptop, and it should not be actively using the webcam (it just has a hold on the device for whatever reason). To bypass this, I'd like to know if there's anything I can do to let multiple programmes access the camera at the same time (or for anyone familiar with the client, how do I remove the hold on the video from uTox?), as I generally need to have uTox running in the background. Killing the process so I can take a Skype call is very inconvenient.
Is there any way I can allow multiple programmes to access the same video device at the same time?
Error upon running Cheese:
$ cheese &
libv4l2: error setting pixformat: Device or resource busy
(cheese:8259): cheese-WARNING **: Device '/dev/video0' is busy: gstv4l2object.c(2838): gst_v4l2_object_set_format (): /GstCameraBin:camerabin/GstWrapperCameraBinSrc:camera_source/GstBin:bin18/GstV4l2Src:video_source:
Call to S_FMT failed for YU12 @ 1280x720: Device or resource busy
System info:
$ lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description: Ubuntu 15.04
Release: 15.04
Codename: vivid
# lshw -short
H/W path Device Class Description
system Computer
/0 bus Motherboard
/0/0 memory 7873MiB System memory
/0/1 processor Intel(R) Core(TM) i5-3337U CPU @ 1.80GHz
/0/100 bridge 3rd Gen Core processor DRAM Controller
/0/100/2 display 3rd Gen Core processor Graphics Controller
/0/100/14 bus 7 Series/C210 Series Chipset Family USB xHCI Host Controller
/0/100/14/0 usb2 bus xHCI Host Controller
/0/100/14/1 usb1 bus xHCI Host Controller
/0/100/16 communication 7 Series/C210 Series Chipset Family MEI Controller #1
/0/100/1a bus 7 Series/C210 Series Chipset Family USB Enhanced Host Controller #2
/0/100/1a/1 usb3 bus EHCI Host Controller
/0/100/1a/1/1 bus Integrated Rate Matching Hub
/0/100/1a/1/1/1 communication Bluetooth wireless interface
/0/100/1a/1/1/3 multimedia HD WebCam
/0/100/1b multimedia 7 Series/C210 Series Chipset Family High Definition Audio Controller
/0/100/1c bridge 7 Series/C210 Series Chipset Family PCI Express Root Port 1
/0/100/1c/0 eth0 network NetXtreme BCM57786 Gigabit Ethernet PCIe
/0/100/1c/0.1 generic BCM57765/57785 SDXC/MMC Card Reader
/0/100/1c.1 bridge 7 Series/C210 Series Chipset Family PCI Express Root Port 2
/0/100/1c.1/0 wlan0 network QCA9565 / AR9565 Wireless Network Adapter
/0/100/1d bus 7 Series/C210 Series Chipset Family USB Enhanced Host Controller #1
/0/100/1d/1 usb4 bus EHCI Host Controller
/0/100/1d/1/1 bus Integrated Rate Matching Hub
/0/100/1f bridge HM77 Express Chipset LPC Controller
/0/100/1f.2 storage 7 Series Chipset Family 6-port SATA Controller [AHCI mode]
/0/100/1f.3 bus 7 Series/C210 Series Chipset Family SMBus Controller
Note that the video device in concern here is the 'HD Webcam' referred to by lshw located at /dev/video0
