I tried sudo apt-get install xubuntu-desktop. It turned out like this:
Reading package lists... Done
Building dependency tree
 xubuntu-desktop : Depends: gtk2-engines-pixbuf but it is not going to be installed
                   Recommends: abiword but it is not going to be installed
                   Recommends: abiword-plugin-grammar but it is not going to be installed
                   Recommends: abiword-plugin-mathview but it is not going to be installed
                   Recommends: brltty-x11 but it is not going to be installed
                   Recommends: gimp but it is not going to be installed
                   Recommends: gthumb but it is not going to be installed
Anyone knows what this means and how to fix it ?
  • PS: If I have installed Xubuntu-desktop, how can I remove the Unity?
  • Thank you.
Maleficent
  • 51
Seems like you had a broken update or software install so either your apt-cache is messed up or your dpkg isn't getting a lock. First try
sudo dpkg --configure -a
Then:
sudo apt-get update
sudo apt-get autoclean
sudo apt-get clean
sudo apt-get autoremove
sudo dpkg --remove -force --force-remove-reinstreq broken-packagename
Optionally to remove unity:
sudo apt-get purge ubuntu-default-settings
sudo apt-get purge ubuntu-desktop
You should something like this:
sudo apt install xubuntu-desktop <and its dependencies separated by space>
In your error it should be like:
sudo apt install xubuntu-desktop gtk2-engines-pixbuf abiword abiword-plugin-grammar abiword-plugin-mathview brltty-x11 gimp gthumb
Kulfy
  • 18,154
Player1
  • 151
-1
Have you tried installing the base xfce desktop package called "xfce4"? Installing that will install the base xfce desktop, without all of the extra packages used by Xubuntu (eg, gnome-dependencies, xubuntu artwork, etc). This way you wouldn't have more than one text editor, update manager, cd burner, audio player, etc (because thay are all required by Xubuntu).
After installing XUbuntu , you can remove Unity by
sudo apt-get autoremove --purge unity unity-common unity-services unity-lens-\* unity-scope-\* unity-webapps-\* gnome-control-center-unity hud libunity-core-6\* libunity-misc4 libunity-webapps\* appmenu-gtk appmenu-gtk3 appmenu-qt\* overlay-scrollbar\* activity-log-manager-control-center firefox-globalmenu thunderbird-globalmenu libufe-xidgetter0 xul-ext-unity xul-ext-webaccounts webaccounts-extension-common xul-ext-websites-integration gnome-control-center gnome-session
Mayur Kulkarni
  • 550
  • 14
