I am trying to install a program I downloaded, linpac.
I opened the README, and it claimed all I have to do is ./confugure;make;make install but I am stuck on the ./configure because there is no configure file.
There is a configure.ac file, so I ran the command autoconf but I was returned with the error:
autoconf: error: no input file
What are the next steps I can take to try to install my program?
Prashant Chikhalkar
  • 2,451
  • 19
  • 25
According to the linpac-0.21 README:
Release packages can be identified by the presence of the ./configure in
this directory. If the ./configure script is not present, then see the
'Hacking' instructions below.
The instructions are:
NOTES FOR HACKING
A clean checkout from the GIT source repository is not ready to configure
and compile. You will need the GNU autotools
(https://en.wikipedia.org/wiki/GNU_build_system) to create the
./configure script and Makfile templates. Once the autotools are
installed the full build procedure is:
    autoreconf --install
    ./configure
    make
    make install
So it seems you need to run autoreconf --install rather than plain autoconf. Alternatively, you could consider using linpac-0.20 instead, which appears to be the most up-to-date release version.
steeldriver
  • 142,475
