I was using Ubuntu 12.04 LTS on my Dell Vostro laptop. Yesterday I upgraded the same into Ubuntu 14.04 LTS, after upgrading my wired ethernet connection is getting automatically disconnected after connecting into wired net for 3 to 5 minutes, only unplugging and replugging ethernet cable reset the connection and I can access net (It showing it is "connected" in the network connection area, but i cant access internet till I unplug and reconnect it), the problem continue in every 3 to 5 minutes.
Output of lspci -knn | grep Eth -A2
07:00.0 Ethernet controller [0200]: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller [10ec:8168] (rev 0c)
Subsystem: Dell Device [1028:065c]
Kernel driver in use: r8168
Pilot6
  • 92,041
SHAL
  • 53
This adapter [10ec:8168] does not need r8168 driver.
Default r8169 module supports it better.
You can test it by
sudo modprobe -r r8168
sudo modprobe r8169
If you installed r8168 from Ubuntu repositories, then run
sudo apt-get purge r8168-dkms
to make it permanent.
Pilot6
  • 92,041
