I have uninstalled a package and i have added the ppa via terminal for example.
I have to know that the packages have uninstalled successfully without leaving any file in my computer.
Is there any Command line to check it whether it was removed without leaving a single file?
I'm using Ubuntu14.04
If the package maintainer is a good package maintainer, then the following should be enough:
To remove a package completely, use
 sudo apt-get purge package_name
But it can be, that some configuration files exists in your home folder. This files will not be removed by the command above.
As I don't know your package name, simply start a search
find ~ -maxdepth 1 -iname '*package_name*''
And
find ~/.config -iname '*package_name*''
Don't remove the * from the search pattern. Change only the package_name.
But if you in doubt, start a full scan
sudo   find / -iname '*package_name*''
A.B.
  • 92,125
