I am unable to open Software Centre. When I do try to open it the window opens for a couple of minutes and then closes. When I attept to run in terminal I get this message:
2015-08-01 21:40:27,619 - softwarecenter.ui.gtk3.app - INFO - setting up proxy 'None'
2015-08-01 21:40:28,289 - softwarecenter.backend.reviews - WARNING - Could not get usefulness from server, no username in config file
2015-08-01 21:40:28,291 - softwarecenter.plugin - INFO - activating plugin '<module 'webapps_activation' from '/usr/share/software-center/softwarecenter/plugins/webapps_activation.pyc'>'
2015-08-01 21:40:28,335 - softwarecenter.db.pkginfo_impl.aptcache - INFO - aptcache.open()
2015-08-01 21:40:29,453 - softwarecenter.backend.reviews - WARNING - error creating bsddb: '(22, 'Invalid argument -- BDB0054 illegal flag combination specified to DB_ENV->open')' (corrupted?)
2015-08-01 21:40:29,454 - softwarecenter.backend.reviews - ERROR - trying to repair DB failed
Traceback (most recent call last):
  File "/usr/share/software-center/softwarecenter/backend/reviews/__init__.py", line 358, in _save_review_stats_cache_blocking
    self._dump_bsddbm_for_unity(outfile, outdir)
  File "/usr/share/software-center/softwarecenter/backend/reviews/__init__.py", line 377, in _dump_bsddbm_for_unity
    0600)
DBInvalidArgError: (22, 'Invalid argument -- BDB0054 illegal flag combination specified to DB_ENV->open')
/usr/lib/python2.7/dist-packages/gi/overrides/GLib.py:535: Warning: Source ID 74 was not found when attempting to remove it
  return super(MainContext, self).iteration(may_block)
  File "/usr/share/software-center/softwarecenter/db/pkginfo_impl/aptcache.py", line 261, in open
    self._cache = apt.Cache(progress)
  File "/usr/lib/python2.7/dist-packages/apt/cache.py", line 107, in __init__
    self.open(progress)
  File "/usr/lib/python2.7/dist-packages/apt/cache.py", line 151, in open
    self._cache = apt_pkg.Cache(progress)
SystemError: E:Encountered a section with no Package: header, E:Problem with MergeList /var/lib/apt/lists/repo.steampowered.com_steam_dists_precise_steam_i18n_Translation-en, E:The package lists or status file could not be parsed or opened.
2015-08-01 21:40:32,046 - softwarecenter.db.enquire - ERROR - _get_estimate_nr_apps_and_nr_pkgs failed
  File "/usr/share/software-center/softwarecenter/db/enquire.py", line 115, in _get_estimate_nr_apps_and_nr_pkgs
    tmp_matches = enquire.get_mset(0, len(self.db), None, xfilter)
  File "/usr/share/software-center/softwarecenter/db/appfilter.py", line 89, in __call__
    if (not pkgname in self.cache and
  File "/usr/share/software-center/softwarecenter/db/pkginfo_impl/aptcache.py", line 281, in __contains__
    return self._cache.__contains__(k)
AttributeError: 'NoneType' object has no attribute '__contains__'
  File "/usr/bin/software-center", line 183, in <module>
    app.run(args)
  File "/usr/share/software-center/softwarecenter/ui/gtk3/app.py", line 1378, in run
    self.show_available_packages(args)
  File "/usr/share/software-center/softwarecenter/ui/gtk3/app.py", line 1316, in show_available_packages
    self.view_manager.set_active_view(ViewPages.AVAILABLE)
  File "/usr/share/software-center/softwarecenter/ui/gtk3/session/viewmanager.py", line 150, in set_active_view
    view_widget.init_view()
  File "/usr/share/software-center/softwarecenter/ui/gtk3/panes/availablepane.py", line 227, in init_view
    self.cache, self.db, self.icons, self.apps_filter)
  File "/usr/share/software-center/softwarecenter/ui/gtk3/views/lobbyview.py", line 80, in __init__
    self.build()
  File "/usr/share/software-center/softwarecenter/ui/gtk3/views/lobbyview.py", line 326, in build
    self._build_homepage_view()
  File "/usr/share/software-center/softwarecenter/ui/gtk3/views/lobbyview.py", line 121, in _build_homepage_view
    self._append_whats_new()
  File "/usr/share/software-center/softwarecenter/ui/gtk3/views/lobbyview.py", line 255, in _append_whats_new
    whats_new_cat = self._update_whats_new_content()
  File "/usr/share/software-center/softwarecenter/ui/gtk3/views/lobbyview.py", line 240, in _update_whats_new_content
    docs = whats_new_cat.get_documents(self.db)
  File "/usr/share/software-center/softwarecenter/db/categories.py", line 131, in get_documents
    nonblocking_load=False)
  File "/usr/share/software-center/softwarecenter/db/enquire.py", line 330, in set_query
    self._blocking_perform_search()
  File "/usr/share/software-center/softwarecenter/db/enquire.py", line 225, in _blocking_perform_search
    matches = enquire.get_mset(0, self.limit, None, xfilter)
montem@Zalman:~$ Traceback (most recent call last):
  File "/usr/share/software-center/update-software-center-agent", line 81, in <module>
    cache = apt.Cache(memonly=True)
    self.open(progress)
I tried to update ubuntu in the hopes that it would fix the problem, but that does not seem to do anything. The Problem started to occur after Steam had issues updating. I do not know if it is relevant but here is the message that I was given was:
Steam needs to install these additional packages:
    libgl1-mesa-dri:i386, libgl1-mesa-glx:i386
[sudo] password for montem:
....................................................................................................................E: Encountered a section with no Package: header
E: Problem with MergeList /var/lib/apt/lists/repo.steampowered.com_steam_dists_precise_steam_i18n_Translation-en
E: The package lists or status file could not be parsed or opened.
Reading package lists... Error!
Press return to continue:
How do I fix this?
JoKeR
  • 7,062
Montem
  • 49
It looks like the steam list is empty or is broken and this disturbs your package update.
My first try would be to move all the steam-lists from /var/lib/apt/lists to a temporary directory in my home folder and also move the steam PPA settings from /etc/apt/sources.d to that.
Then do an apt-get update again and look if the cache setup is now working again. If it is then add again the steam PPA to /etc/apt/sources.d and again do an apt-get update. If you get the same error message as above then you need to update your steam PPA maybe. I expect that the software-center is working again when the apt cache does not have any failures anymore.
thedler
  • 314
