I got a new computer (Dell inspiron 3000 series) was a system of Ubuntu I turned it on Windows 7 . I want to have again the old system what to do. ?
Asked
Active
Viewed 50 times
Installing Ubuntu is pretty easy if you know what you are doing.First use a USB.After that turn off Secure Boot as that makes the ISO unbootable.Then burn the Ubuntu ISO to the USB using a program like Rufus(Don't use UNETBOOTIN it's broken).Then restart your computer and access the BIOS.In there select your USB device.After that you should see the Ubuntu install screen and you should be able to install Ubuntu.
