I'm new to linux but I know about the startx command which is not working. I just installed Ubuntu Server (the newest version) on a old computer. I have it working but I am unable to launch the gui. I cannot connect to the internet because I don't have a network adapter. How would I start the gui?
Ubuntu Server does not come with a GUI. Its Headless, IE: Command Line Only. You would need to run an APT-GET command which requires internet.
If you get network capabilities check out..
Install GUI on Ubuntu Server
FreeSoftwareServers
  • 1,129
  • 14
  • 32
Even when @FreeSoftwareServers is true, there's a way to install a GUI, download a desktop version of ubuntu, i think xubuntu (xfce) is more suitable since it's an old computer (limited resources). Burn the cd and put it on the machine.
Then you have to create a dir to mount the cd
sudo mkdir -p /mnt/cdrom
Mount the cd on that dir, and check it ( instructions here if this doesn't work )
mount -t iso9660 -o ro /dev/cdrom /mnt/cdrom
du
That should show something like
/dev/sr0    952320    952320    0    100%   /mnt/cdrom
Then add the cd as apt source
sudo apt-cdrom -m --cdrom=/mnt/cdrom add
Then update the sources
sudo apt-get update
Install xfce4 and slim
sudo apt-get install xfce4 slim
Finally reboot the machine
sudo reboot
Note: the login didn't work the first time but from that point it worked properly.
bistoco
  • 1,541
