This is the error coming. I have shut down windows properly and yet this error comes.
Error mounting /dev/sda7 at /media/harshit/Movies and songs:
Command-line `mount -t "ntfs" -o "uhelper=udisks2,nodev,nosuid,uid=1000,gid=1000,dmask=0077,fmask=0177" "/dev/sda7" "/media/harshit/Movies and songs"' exited with non-zero exit status 14: The disk contains an unclean file system (0, 0).
Metadata kept in Windows cache, refused to mount.
Failed to mount '/dev/sda7': Operation not permitted
The NTFS partition is in an unsafe state. Please resume and shutdown
Windows fully (no hibernation or fast restarting), or mount the volume
read-only with the 'ro' mount option.
Pilot6
  • 92,041
when you shutting down window's 8.1 instead of shutting down through the menu panel, shut it down using force command to do this
  1. Press windows button and R key when you are in window's 8.1.
  2. when the run prompt up type in that :-
  3. shutdown -s -f -t 00
  4. comment: -s for shutdown, -r for reboot use whichever you required.
  5. And press enter
  6. And when you reboot into ubuntu you can easily mount windows partition in it.
Gaurav
  • 143
  • 14
