How do I enable Asus Fliplock? The touchscreen works great, but it does not disable the keyboard and trackpad when i turn the screen over. Thanks
Asked
Active
Viewed 1,560 times
There is not any "built-in" support for Asus FLipLock. I have come up with a script that toggles those.
#!/bin/bash
#toggle keyboard and touchpad
key_device=12
key_property=138
touch_device=13
touch_property=138
flipped_state=$(xinput list-props "$key_device" | awk"/\\($key_property\\)/{print 1 - \$NF}")
xinput set-prop "$touch_device" "$touch_property" "$flipped_state"
xinput set-prop "$key_device" "$key_property" "$flipped_state"
#toggle onboard
#dbus-send --type=method_call --est=org.onboard.Onboard/org/onboard/Onboard/Keyboard org.onboard.Onboard.Keyboard.ToggleVisible
I commented out the onboard touch keyboard, as I could not get this function to work, and there are other ways to configure your onscreen keyboard.
I created a launcher for this, and added to my panel. Now I can turn those on and off at will.
I used this to modify my arandr generated scripts to rotate touch input with the display: Touchscreen Input Doesn't Rotate: Lenovo Yoga 13 / Yoga 2 Pro
