27
is there a way to find out the PCI bus number of an Ethernet interface or vice versa. I am looking to write a Bash/Python script which gives some thing like
pci_address = some_function(eth0)
where pci_address is sys:bus:slot:function. How can these two elements be related to each other?
Waqas
  • 819
6 Answers6
46
lshw and lspci are both capable of showing that information. As you have found out already, you can do lshw -class network -businfo. For instance, here's my output:
$ sudo lshw -c network -businfo
Bus info          Device      Class       Description
pci@0000:0e:00.0  wlan0       network     RTL8187SE Wireless LAN Controller
pci@0000:14:00.0  eth0        network     RTL8101E/RTL8102E PCI Express Fast Ethernet controller
What you also could use is lspci -D and pipe it to grep to filter out the ethernet controller specifically. Here's my example:
$ lspci -D | grep 'Network\|Ethernet'
    0000:0e:00.0 Network controller: Realtek Semiconductor Co., Ltd. RTL8187SE Wireless LAN Controller (rev 22)
    0000:14:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8101E/RTL8102E PCI Express Fast Ethernet controller (rev 02)
Note that with the transition to systemd, one could use of Predictable Interface Naming to just look at the interface name to find out PCI information.
30
This information is available in sysfs, no helpers like lshw / lspci / ethtool / udevadm are needed:
$ grep PCI_SLOT_NAME /sys/class/net/*/device/uevent
/sys/class/net/enp4s0/device/uevent:PCI_SLOT_NAME=0000:04:00.0
/sys/class/net/wlp2s0/device/uevent:PCI_SLOT_NAME=0000:02:00.0
14
ethtool will also show you pci for an interface (bus-info:)
me@ubuntu:~$ ethtool -i eth0
driver: i40e
version: 1.5.16
firmware-version: 5.04 0x800024cd 0.0.0
bus-info: 0000:06:00.0
supports-statistics: yes
supports-test: yes
supports-eeprom-access: yes
supports-register-dump: yes
riotejas
  • 1,006
It looks you can tie them together by the IRQ.
ifconfig -a
will print the ethernet devices including Interrupt.
eg.
eth2      Link encap:Ethernet  HWaddr 00:25:11:19:8b:77
          inet addr:192.168.1.3  Bcast:192.168.1.255  Mask:255.255.255.0
          inet6 addr: fe80::225:11ff:fe19:8b77/64 Scope:Link
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:39958 errors:0 dropped:0 overruns:0 frame:0
          TX packets:34512 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:21410099 (21.4 MB)  TX bytes:4802798 (4.8 MB)
          Interrupt:43 Base address:0xa000
while
lspci -v
gives the PCI info with IRQ
eg.
04:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8101E/RTL8102E PCI Express Fast Ethernet controller (rev 01)
    Subsystem: Acer Incorporated [ALI] Device 0245
    Flags: bus master, fast devsel, latency 0, IRQ 43
    I/O ports at e800 [size=256]
    Memory at febff000 (64-bit, non-prefetchable) [size=4K]
    Expansion ROM at febc0000 [disabled] [size=128K]
    Capabilities: <access denied>
    Kernel driver in use: r8169
    Kernel modules: r8169
since I see both are 43 I can infer that eth2 matches 04:00.0
A.B.
  • 92,125
Sorry but PCI_SLOT_NAME in uevent isn't a PCI slot number, it is the bus.
On HP H/W you can use bus number to look up the PCI slot number from the output of hplog -i.
But I can't find similar utility for Oracle Linux on Sun H/W like M2s You can get some information using lspci -vmm & looking for PhySlot entries.
This is for older systems before Dell's biosdevnames.
Greenonline
  • 2,182
Another solution, using udevadm
udevadm info -a -p /sys/class/net/eth{0..10} | awk '/device.*eth/'
{0..10} – checks the initerfaces from eth0eth10
Therefore you could use this command
pci_address=$(udevadm info -a -p /sys/class/net/eth{0..10} | awk -F/ '/device.*eth/ {print $4}')
Example output
looking at device '/devices/pci0000:00/0000:00:03.0/net/eth0':
Therefore the address is
0000:00:03.0
Or in your case with a single command
% pci_address=$(udevadm info -a -p /sys/class/net/eth{0..10} | awk -F/ '/device.*eth/ {print $4}')
% echo $pci_address
0000:00:03.0
or in a script
#!/bin/bash
udevadm info -a -p /sys/class/net/"$1" | awk -F/ '/device.*eth/ {print $4}'
Call the script with
script_name eth0
Output is
0000:00:03.0
A.B.
  • 92,125
