I decided to upgrade my windows 8 to windows 10. During the installation process, the computer rebooted and I got into the grub console, without having my usual menu.
I was able to proceed to the installation and use windows by choosing which hdd to boot on on my bios, but after the installation I can't boot into ubuntu again. Same issue with a grub shell.
On the grub shell, I tried to use ls (hdx,y)/ to display the information about the filesystems. Only one or two were readable, while the other always responded as unknown filesystem.
I booted on a boot-repair live disc, and was able to use the boot-repair tool, but it didn't fix anything and I still have the same issue.
Here is the boot info : http://paste.ubuntu.com/11969079/
What should I do to repair my grub install and be able to boot on linux?
EDIT: using fsck I got the following result :
lubuntu@lubuntu:~$ sudo e2fsck -C0 -p -f -v /dev/sdb6
e2fsck: Bad magic number in super-block while trying to open /dev/sdb6
/dev/sdb6:
The superblock could not be read or does not describe a valid ext2/ext3/ext4
filesystem.  If the device is valid and it really contains an ext2/ext3/ext4
filesystem (and not swap or ufs or something else), then the superblock
is corrupt, and you might try running e2fsck with an alternate superblock:
    e2fsck -b 8193 <device>
 or
    e2fsck -b 32768 <device>
lubuntu@lubuntu:~$
I believe /dev/sdb6 was the partition where my system was installed while /dev/sdb2 was where I had my /boot.
I'm unable to mount /dev/sdb6 on a linux livecd.
I did it by run live-cd with Ubuntu (can be any other distro) and install boot-repair. Everything is written here: https://help.ubuntu.com/community/Boot-Repair
Run in live-cd terminal
sudo add-apt-repository ppa:yannubuntu/boot-repair
sudo apt-get update
sudo apt-get install -y boot-repair && boot-repair
Then just click Recommended Repair. This works, i have used it a few times.
iacobus
  • 514
The options are: 1. CMOS. HDD2 can be replaced first, it is different. 2. LIVE CD and reinstall GRUB on the first partition.It is not always possible. 3. Do an external drive system. 16 MB is enough. Basic ubuntu and suggested programs: Synaptic - installs GRUB and useful package manager. Gparted knows everything about the partitions and do everything. This is dangerous, do not make mistakes. Midnight Commander is also operating console over-File's control. With these you can improve many mistakes. Space shall be that the programs work.
