I'm trying to install Gulp.
As the author says it needs 32-bit libpcap-dev libs for building the application, but when I try to download 32bit version it says
NO INSTALL CANDIDATE AVAILABLE
How do I solve this?
I'm running Ubuntu 14.04 LTS 64-bit
libcap-dev (both 32 and 64 bits) are available in Ubuntu 14.04's main repo.
$ apt-cache policy libcap-dev:i386
libcap-dev:i386:
Installed: (none)
Candidate: 1:2.24-0ubuntu2
Version table:
1:2.24-0ubuntu2 0
500 http://us.archive.ubuntu.com/ubuntu/ trusty/main i386 Packages
I think you have not enabled the multiarch support leading to that error about non-existent package.
To enable multiarch support for i386 architecture so that you can install 32 bit packages on your 64 bit system :
sudo dpkg --add-architecture i386
Now run :
sudo apt-get update
Now you should be able to install libcap-dev (32 bit) :
sudo apt-get install libcap-dev:i386
