Recently, the Internet was been acting strange on my Ubuntu partition. It works 100% fine when I dual-boot Windows, but the Ubuntu partition connects to wifi for an indeterminate amount of time (0-10 minutes) before dying and not-working...
I'm running 14.04, which I installed and re-installed yesterday.
ping 8.8.8.8 usually works for a few minutes after I power on my laptop, but after that it returns the Host Unreachable error.
I have read several articles on this site on the same issue and cannot find a solution. I've attached terminal output from several commands I saw users asking for:
route -n output: I don't know much about what's going on, but this looks erroneous
Kernel IP routing table
Destination     Gateway         Genmask         Flags Metric Ref    Use Iface
0.0.0.0         172.31.98.1     0.0.0.0         UG    0      0        0 wlan0
172.31.98.0     0.0.0.0         255.255.254.0   U     9      0        0 wlan0
grep wl /etc/modprobe.d/* output:
/etc/modprobe.d/blacklist-watchdog.conf:blacklist twl4030_wdt
/etc/modprobe.d/iwlwifi.conf:# /etc/modprobe.d/iwlwifi.conf
/etc/modprobe.d/iwlwifi.conf:# iwlwifi will dyamically load either iwldvm or iwlmvm depending on the
/etc/modprobe.d/iwlwifi.conf:# microcode file installed on the system.  When removing iwlwifi, first
/etc/modprobe.d/iwlwifi.conf:# remove the iwl?vm module and then iwlwifi.
/etc/modprobe.d/iwlwifi.conf:remove iwlwifi \
/etc/modprobe.d/iwlwifi.conf:(/sbin/lsmod | grep -o -e ^iwlmvm -e ^iwldvm -e ^iwlwifi | xargs /sbin/rmmod) \
rfkill list output:
0: ideapad_wlan: Wireless LAN
    Soft blocked: no
    Hard blocked: no
1: ideapad_bluetooth: Bluetooth
    Soft blocked: no
    Hard blocked: no
2: hci0: Bluetooth
    Soft blocked: no
    Hard blocked: no
3: phy0: Wireless LAN
    Soft blocked: no
    Hard blocked: no
iwconfig output:
eth0      no wireless extensions.
wlan0     IEEE 802.11bgn  ESSID:"Google Starbucks"
          Mode:Managed  Frequency:2.412 GHz  Access Point: 18:64:72:65:86:20
          Bit Rate=72.2 Mb/s   Tx-Power=20 dBm
          Retry short limit:7   RTS thr=2347 B   Fragment thr:off
          Power Management:off
          Link Quality=70/70  Signal level=-33 dBm
          Rx invalid nwid:0  Rx invalid crypt:0  Rx invalid frag:0
          Tx excessive retries:0  Invalid misc:42   Missed beacon:0
lo        no wireless extensions.
ifconfig output:
eth0      Link encap:Ethernet  HWaddr 54:ee:75:28:64:8d
          UP BROADCAST MULTICAST  MTU:1500  Metric:1
          RX packets:0 errors:0 dropped:0 overruns:0 frame:0
          TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:0 (0.0 B)  TX bytes:0 (0.0 B)
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          inet6 addr: ::1/128 Scope:Host
          UP LOOPBACK RUNNING  MTU:65536  Metric:1
          RX packets:225 errors:0 dropped:0 overruns:0 frame:0
          TX packets:225 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:0
          RX bytes:16928 (16.9 KB)  TX bytes:16928 (16.9 KB)
wlan0     Link encap:Ethernet  HWaddr b0:10:41:8a:ee:47
          inet addr:172.31.99.170  Bcast:172.31.99.255  Mask:255.255.254.0
          inet6 addr: fe80::b210:41ff:fe8a:ee47/64 Scope:Link
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:198 errors:0 dropped:0 overruns:0 frame:0
          TX packets:341 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:257409 (257.4 KB)  TX bytes:34163 (34.1 KB)
lsusb output:
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 005: ID 03eb:8a1b Atmel Corp.
Bus 001 Device 004: ID 0bda:b728 Realtek Semiconductor Corp.
Bus 001 Device 003: ID 046d:c52b Logitech, Inc. Unifying Receiver
Bus 001 Device 002: ID 5986:055d Acer, Inc
lspci -nnk | grep -iA2 net output:
02:00.0 Network controller [0280]: Realtek Semiconductor Co., Ltd. RTL8723BE PCIe Wireless Network Adapter [10ec:b723]
    Subsystem: Lenovo Device [17aa:b736]
    Kernel driver in use: rtl8723be
03:00.0 Ethernet controller [0200]: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller [10ec:8168] (rev 10)
    Subsystem: Lenovo Device [17aa:3810]
    Kernel driver in use: r8169
Pilot6
  • 92,041
I solved the problem by re-installing the drivers offered by Lenovo on my Windows partition. Even though the problem was with Ubuntu, and even though the drivers were previously installed (hence me being able to initially connect to the Internet on Ubuntu), the re-installing of the Lenovo drivers on my Windows partition somehow fixed the Ubuntu dropped connection issue as well
