You need three redirects to do what you want:
http://example.com to https://www.example.com
http://www.example.com to https://www.example.com
https://example.com to https://www.example.com
The first two are from port 80 plain HTTP so you have a VirtualHost for them. You can make a VirtualHost section apply to more than one hostname (www.example.com and example.com) by having a ServerAlias section:
# Redirect http://example.com and http://www.example.com to main site
<VirtualHost *:80>
ServerName www.example.com
ServerAlias example.com
Redirect / https://www.example.com/
</VirtualHost >
Then, you need a VirtualHost for your https://example.com only. HTTPS uses port 443:
# Redirect https://example.com to main site
<VirtualHost *:443>
ServerName example.com
</VirtualHost >
Note: you'll need to set up your SSL settings there too, with a certificate that supports BOTH the domain with and without the "www.". Setting up your SSL settings is outside the scope of this question. (Added info: these can be two separate certificates if you like; it's becoming more common to have lots of separate certs now we have things like Let's Encrypt and SNI)
If you don't have an SSL certificate that supports your domain without the "www." then you won't be able to do the redirect from https://example.com. The redirect will only happen after the browser checks the certificate. The user would be presented with a mismatched certificate error.
Then, finally, you need your VirtualHost section for the "valid" site: HTTPS (port 443) on www.example.com:
# Main site
<VirtualHost *:443>
# Put all your configuration for this site here
</VirtualHost >
Once you have tested your redirects and you're happy they are working, you can make them permanent by specifying the 301 status in the redirect (change Redirect / https://www.example.com/ to Redirect 301 / https://www.example.com/ everywhere), and by enabling HSTS which forces users' browsers to remember the preference for HTTPS.
