In RPM, there is a (much maligned, but nonetheless it is there) field called EPOCH, used to override a version stream with lower numbering.
It is a source of constant trouble, but in the cases where it is needed, EPOCH is often the only way to go.
Does the DEB package format have a similar field?
0xF2
  • 3,155
Looks like the simple answer is that Debian packages also have an epoch field.
From the policy manual: version fields
0xF2
  • 3,155
