15
In older versions of Ubuntu I commented out the "start on ..." line in /etc/init/ssh.conf. This worked well, but not in Ubuntu 15.04.
Fango
  • 491
The command
systemctl disable ssh
did it for me.
@Jakuje: Thanks for giving me the idea.
A.B.
  • 92,125
Fango
  • 491
This is documented in man systemctl:
prevents ssh service from automatic starting. But this is the way systemd does it, but ubuntu does not accept it and they have to do it their own way:
Official documentation: https://wiki.ubuntu.com/SystemdForUpstartUsers#Automatic_starting
According to this you should create unit override without directive WantedBy=multi-user.target in /etc/systemd/system/ssh.service (instead of the current symlink):
rm /etc/systemd/system/ssh.service
cp /lib/systemd/system/ssh.service /etc/systemd/system/ssh.service
sed -e "/WantedBy=multi-user.target/d" -i /etc/systemd/system/ssh.service
systemctl daemon-reload
Jakuje
  • 6,793
I want to disable a service and systemctl disable myservice doesn't work, but run a systemctl daemon-reload after disabling makes it disable.
SAMPro
  • 111
It does a bit more than requested, but the foolproof approach is to remove the package:
sudo apt-get remove openssh-server
This works in all versions of Ubuntu.
Assuming you have internet access, or have cached the package, reinstalling (and automatically restarting) is not a problem:
sudo apt-get install openssh-server
