I would like to be able to go anywhere (google chrome, sublime text editor, etc), then highlight + right click on some text, then click a custom right-click-menu button which will run a python script with the highlighted text as input. Is there any tool to do this in Ubuntu 14.04+?
I am aware of Nautilus, however Nautilus right-click commands don't seem to show up on google chrome or sublime text editor, and also I am not aware of any way Nautilus can pass highlighted text as input to a python script.
It would be quite useful to have this capacity, as it would let me automate some tedious aspects of my work-flow, so I wonder if there is a right tool for the job?
Thanks in advance!
Another usage of xclip
The solution below uses xclip. xclip is not on your system by default, you will have to install it:
sudo apt-get install xclip
In its simplest form, you could do it in a very short script with the help of xclip. When we use the xclip -o command, the currently selected text is used to output, or as man xclip mentions:
   -o, -out
          print the selection to standard out (generally for piping to a
          file or program)
Using this, we can easily use the selected text to do anything, e.g.
#!/bin/bash
# get the currently selected text
text=$(xclip -o)
# print the selection into a file in your home directory
echo $text > ~/xclip_output.txt
# opening a file with the selected text as a title, in the current working directory
gedit "$text"
or, in your case:
<script> "$text"
If this exactly matches what you need depends on what you are actually doing with the input text. Possibly you would have to decide what to do with spaces, (single/double) quotes etc, but this is basically "how it can be done".
Adding it to a shortcut key
If you save the script above as use_text.sh, you can simply add it to a shortcut key: choose: System Settings > "Keyboard" > "Shortcuts" > "Custom Shortcuts". Click the "+" and add the command:
/bin/bash /path/to/use_text.sh
to a key combination of your preference
See also: man xclip
Jacob Vlijm
  • 85,475
