I installed postgresql using following command on 25th following instruction on (help.ubuntu.com/community/PostgreSQL)
sudo apt-get install postgres postgresql-contrib
It was working fine. Then on 27th I installed postgres-xc following another tutorial and after that I am getting error "fatal error postgres role not found".
Log of my installation:
2015-07-25 18:11:40 install postgresql-contrib-9.3:amd64 <none> 9.3.9-0ubuntu0.14.04
2015-07-25 18:11:42 install postgresql-contrib:all <none>    9.3+154ubuntu1
2015-07-25 18:15:42 install pgadmin3-data:all <none> 1.18.1-2
2015-07-25 18:15:44 install pgadmin3:amd64 <none> 1.18.1-2
2015-07-25 18:15:47 install pgagent:amd64 <none> 3.3.0-1
2015-07-27 20:53:45 install postgres-xc-client:amd64 <none> 1.1-2ubuntu2
2015-07-27 20:54:32 install postgres-xc:amd64 <none> 1.1-2ubuntu2
After this installation I was suggested to run autoremove by the installation. Here is the log of removed files:
2015-07-27 20:53:25 remove postgresql:all 9.3+154ubuntu1 <none>
2015-07-27 20:53:26 remove postgresql-9.1:amd64 9.1.13-0ubuntu0.13.10 <none>
2015-07-27 20:53:29 remove postgresql-contrib:all 9.3+154ubuntu1 <none>
2015-07-27 20:53:30 remove postgresql-contrib-9.3:amd64 9.3.9-0ubuntu0.14.04 <none>
2015-07-27 20:53:32 remove postgresql-9.3:amd64 9.3.9-0ubuntu0.14.04 <none>
2015-07-27 20:53:35 remove postgresql-client:all 9.3+154ubuntu1 <none>
2015-07-27 20:53:35 remove postgresql-client-9.1:amd64 9.1.13-0ubuntu0.13.10 <none>
2015-07-27 20:53:37 remove postgresql-client-9.3:amd64 9.3.9-0ubuntu0.14.04 <none>
2015-07-27 20:53:37 remove postgresql-common:all 154ubuntu1 <none>
2015-07-27 20:53:39 remove postgresql-client-common:all 154ubuntu1 <none>
2015-07-27 20:55:15 remove libossp-uuid16:amd64 1.6.2-1.3ubuntu1 <none>
I uses apt-get to install postgres-xc. Please advise me how to make my system working again?
tried suggestion from @saji89 as follows:
sudo useradd -r -s /bin/false postgres
the result is
ashutosh@ashUbuntu:~$ sudo useradd -r -s /bin/false postgres
[sudo] password for ashutosh:
useradd: user 'postgres' already exists
Tried reinstallation of postgresql got following failure:
sudo apt-get install --reinstall postgresql postgresql-contrib
Reading package lists... Done
Building dependency tree
 postgresql : Depends: postgresql-9.3 but it is not going to be installed
 postgresql-contrib : Depends: postgresql-contrib-9.3 but it is not going to be installed
tried solution on link https://dba.stackexchange.com/questions/61850/after-installing-postgresql-and-postgres-xc-with-apt-get-i-have-psql-but-not-po
Top two line are commands. First command was silent. Second gave output. But problem exists.
ashutosh@ashUbuntu:~$ sudo updatedb
ashutosh@ashUbuntu:~$ sudo locate initdb
/usr/bin/initdb
/usr/share/locale/cs/LC_MESSAGES/initdb-9.2.mo
/usr/share/locale/de/LC_MESSAGES/initdb-9.2.mo
/usr/share/locale/es/LC_MESSAGES/initdb-9.2.mo
/usr/share/locale/fr/LC_MESSAGES/initdb-9.2.mo
/usr/share/locale/it/LC_MESSAGES/initdb-9.2.mo
/usr/share/locale/ja/LC_MESSAGES/initdb-9.2.mo
/usr/share/locale/ko/LC_MESSAGES/initdb-9.2.mo
/usr/share/locale/pl/LC_MESSAGES/initdb-9.2.mo
/usr/share/locale/pt_BR/LC_MESSAGES/initdb-9.2.mo
/usr/share/locale/ro/LC_MESSAGES/initdb-9.2.mo
/usr/share/locale/ru/LC_MESSAGES/initdb-9.2.mo
/usr/share/locale/sv/LC_MESSAGES/initdb-9.2.mo
/usr/share/locale/tr/LC_MESSAGES/initdb-9.2.mo
/usr/share/locale/zh_CN/LC_MESSAGES/initdb-9.2.mo
/usr/share/locale/zh_TW/LC_MESSAGES/initdb-9.2.mo
/usr/share/man/man1/initdb.1.gz
Use steps in how to unistall postgres-x to uninstall.
Then reinstall postgresql using
Ensure to check your port number, as it might have been changed (It was changed in my case).
select *
postgres-# from pg_settings
postgres-# where name = 'port';
Another referred link
