When I try to run something like sudo apt-get install rdesktop, I get this:
Reading package lists... Done
Building dependency tree
You might want to run 'apt-get -f install' to correct these:
linux-image-generic-lts-trusty : Depends: linux-image-3.13.0-55-generic but it is not going to be installed
E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).
When I then trying running sudo apt-get -f install, I get this:
Correcting dependencies... Done
The following extra packages will be installed:
linux-image-3.13.0-58-generic linux-image-generic-lts-trusty
Suggested packages:
fdutils linux-lts-trusty-doc-3.13.0 linux-lts-trusty-source-3.13.0
linux-lts-trusty-tools linux-headers-3.13.0-58-generic
The following NEW packages will be installed:
The following packages will be upgraded:
1 upgraded, 1 newly installed, 0 to remove and 83 not upgraded.
2 not fully installed or removed.
Need to get 0 B/52.5 MB of archives.
After this operation, 198 MB of additional disk space will be used.
Do you want to continue [Y/n]? y
(Reading database ... 353075 files and directories currently installed.)
Unpacking linux-image-3.13.0-58-generic (from .../linux-image-3.13.0-58-generic_3.13.0-58.97~precise1_amd64.deb) ...
Done.
dpkg: error processing /var/cache/apt/archives/linux-image-3.13.0-58-generic_3.13.0-58.97~precise1_amd64.deb (--unpack):
failed in write on buffer copy for backend dpkg-deb during `./boot/vmlinuz-3.13.0-58-generic': No space left on device
No apport report written because the error message indicates a disk full error
dpkg-deb: error: subprocess paste was killed by signal (Broken pipe)
Examining /etc/kernel/postrm.d .
run-parts: executing /etc/kernel/postrm.d/initramfs-tools 3.13.0-58-generic /boot/vmlinuz-3.13.0-58-generic
run-parts: executing /etc/kernel/postrm.d/zz-update-grub 3.13.0-58-generic /boot/vmlinuz-3.13.0-58-generic
Can anyone help me to understand what's going on here? I have read some related questions but am a bit confused.
