I'm trying to install Bugzilla.
I have Phpmyadmin installed in my system so I can't follow the instructions on the Bugzilla site that tells me to remove the /var/www/html folder because I have Phpmyadmin in there.
Besides I have seen the instructions here on askubuntu, but I don't want to create other users on my machine and I want to install Bugzilla for my default user because I'm the only one who uses this machine.
Here are the steps I followed:
sudo su
apt-get install git nano
apt-get install apache2 mysql-server libappconfig-perl libdate-calc-perl libtemplate-perl libmime-perl build-essential libdatetime-timezone-perl libdatetime-perl libemail-sender-perl libemail-mime-perl libemail-mime-modifier-perl libdbi-perl libdbd-mysql-perl libcgi-pm-perl libmath-random-isaac-perl libmath-random-isaac-xs-perl apache2-mpm-prefork libapache2-mod-perl2 libapache2-mod-perl2-dev libchart-perl libxml-perl libxml-twig-perl perlmagick libgd-graph-perl libtemplate-plugin-gd-perl libsoap-lite-perl libhtml-scrubber-perl libjson-rpc-perl libdaemon-generic-perl libtheschwartz-perl libtest-taint-perl libauthen-radius-perl libfile-slurp-perl libencode-detect-perl libmodule-build-perl libnet-ldap-perl libauthen-sasl-perl libtemplate-perl-doc libfile-mimeinfo-perl libhtml-formattext-withlinks-perl libgd-dev lynx-cur python-sphinx
cd /var/www/html
git clone --branch release-5.0-stable https://git.mozilla.org/bugzilla/bugzilla bugzilla
cd bugzilla
gedit /etc/mysql/my.cnf`
Altered on Line 52: max_allowed_packet=100M
Added as new line 31, in the [mysqld] section: ft_min_word_len=2
mysql -u root -p -e "GRANT ALL PRIVILEGES ON bugs.* TO bugs@localhost IDENTIFIED BY '$my_pass'"
service mysql restart
gedit /etc/apache2/sites-available/bugzilla.conf`
Added:
ServerName localhost
<Directory /var/www/html>
  AddHandler cgi-script .cgi
  Options +ExecCGI
  DirectoryIndex index.cgi index.html
  AllowOverride Limit FileInfo Indexes Options
</Directory>
Then:
a2ensite bugzilla
a2enmod cgi headers expires
service apache2 restart
cd /var/www/html/bugzilla
./checksetup.pl
It gave me some errors so I run:
/usr/bin/perl install-module.pl –all
./checksetup.pl
gedit localconfig
Line 29: set $webservergroup to www-data
Line 67: set $db_pass to the password for the bugs user I have created in MySQL a few steps ago
./checksetup.pl (again)
./testserver.pl http://localhost/
And then I get this error:
strictures.pm extra testing active but couldn't load all modules. Missing were:
  indirect multidimensional bareword::filehandles
Extra testing is auto-enabled in checkouts only, so if you're the author
of a strictures-using module you need to run:
  cpan indirect multidimensional bareword::filehandles
but these modules are not required by your users.
TEST-OK Webserver is running under group id in $webservergroup.
TEST-FAILED Fetch of images/padlock.png failed
Your web server could not fetch http://localhost/images/padlock.png.
Check your web server configuration and try again.
So what did I do wrong?
As you can see I'd like to install Bugzilla /var/www/html/ folder where I have also Phpmyadmin so I will have: /var/www/html/bugzilla.
Thanks.
Edit: after running: cpan indirect multidimensional bareword::filehandles the problem is still:
Edit 2:
Ok, the only thing I found in apache2 logs is /var/log/other_vhosts_access.log:
localhost:80 127.0.0.1 - - [27/Jul/2015:10:29:06 +0200] "GET /images/padlock.png HTTP/1.1" 404 469 "-" "libwww-perl/6.05"
and /var/log/error.log:
[Mon Jul 27 10:14:38.112755 2015] [mpm_prefork:notice] [pid 7477] AH00163: Apache/2.4.7 (Ubuntu) PHP/5.5.9-1ubuntu4.11 mod_perl/2.0.8 Perl/v5.18.2 configured -- resuming normal operations
[Mon Jul 27 10:14:38.112794 2015] [core:notice] [pid 7477] AH00094: Command line: '/usr/sbin/apache2'
Frank
  • 1,583
I am experiencing the same problem with Ubuntu 14.04, apache 2.4.7, bugzilla 5.0. Also wants to set as http://localhost/bugzilla.
The trick was to think... Yes, simply.
You executed:
when in fact you should have used
./testserver.pl http://localhost/bugzilla
since it needs as input the location of itself (yeah, pretty dumb).
Rinzwind
  • 309,379
For me (Linux Mint 17.2; Bugzilla 5.0.1, Apache 2.4.7) this helped (finally, after trying a lot of other things):
Changed AllowOverride Limit FileInfo Indexes Options to AllowOverride All
Josh
I am experiencing the same issue. The problem for me was related to the AllowOverride setting as well. This is in the file /etc/apache2/sites-enabled/000-default.conf and was set to the following:
<VirtualHost *:80>
  <"Directory /var/www/html/bugzilla>
    AddHandler cgi-script cgi
    Options +Indexes +ExecDGI +FollowSymLinks +MultiViews
    AllowOverride Limit
    Order Allow,deny
    Allow from all
  <Directory>
<VirtualHost>
The line AllowOverride was changed to read:
AllowOverride None
The file /etc/apache2/sites-enabled/bugzilla.conf has the following Directory entry:
    Options +ExecCGI +FollowSymLinks
    DirecortryIndex index.cgi index.html
    AllowOverride All
</Directory>
That fixed the issue for me.
Videonauth
  • 33,815
