24
I already use apt-get for most of my package management. Yet, there are times when I occasionally need to use Synaptic to do certain things. I would like to learn the equivalent commands for doing the following things in Synaptic:
  • Check a package's dependencies / dependent packages. (This can be done in Synaptic by viewing the properties of a package).
  • Browse available packages
  • Search (in package names as well as the details/descriptions) for some key. (The search function at the top of synaptic)
  • Check if a package is installed or not
Also, is there a way to find packages that are no longer necessary (e.g. a package no longer in use because I removed a dependency). I have a feeling my system is terribly bloated because I removed certain programs and not all the dependencies went with them.
Braiam
  • 69,112
ladaghini
  • 800
  • Check a package's dependencies / dependent packages. (This can be done in Synaptic by viewing the properties of a package):
    apt-cache depend 'package-name'
    apt-cache rdepend 'package-name'
    apt-cache pkgnames
    apt-cache search '.*'
    apt-cache show 'package-name'
    apt-cache search pattern
    apt-cache --names-only search pattern
    dpkg -l | grep package-name
The last one could not give the desired result, because when the terminal width is narrow the columns are truncated. Safer alternatives are
dpkg-query -Wf '${Package}\n' | grep pkg
dpkg --get-selections | grep pkg
enzotib
  • 96,093
To answer your last question about finding packages that are no longer necessary. You can find packages that are no longer necessary by
sudo deborphan
Also aptitude is per default set to automatically remove unused packages, so I'd suggest you use it instead of apt-get (it has other nice features too). Note that you may have to install deborphan and aptitude since they're not in the default install (they can be installed via apt-get).
If you wanna stick with apt-get you can removed unused packages with
sudo apt-get autoremove
However, I've found that deborphan manages to find more unused packages than both aptitude and apt-get.
Finally, note that both a aptitude and apt-get can remove old packages from the archives on your computer with the autoclean option:
sudo aptitude autoclean
sudo apt-get autoclean
Aptitude can also be set so that it does this automatically.
N.N.
  • 18,589
"Also, is there a way to find packages that are no longer necessary (e.g. a package no longer in use because I removed a dependency)."
Install deborphan. The default mode gives a list of library packages that aren't depended on by anything - you can also use -a to get a list of all packages [which will obviously include quite a few you want to keep, but you can get an idea of what you have that you may not want that removing won't affect anything else]
Random832
  • 1,155
