I installed 15.04 on my Thinkpad W520. However, I'm not able to get IPv6 working on wlan1 interface:
ifconfig wlan1
wlan1 Link encap:Ethernet HWaddr 8c:70:5a:d2:65:bc
inet addr:10.0.1.61 Bcast:10.0.1.255 Mask:255.255.255.0
inet6 addr: fe80::8e70:5aff:fed2:65bc/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:1534790 errors:0 dropped:0 overruns:0 frame:0
TX packets:1281764 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:618961336 (618.9 MB) TX bytes:249411071 (249.4 MB)
In the Wireshark I'm able to see ICMPv6 RA messages:
No. Time Source Destination Protocol Length Info
3 775.989536000 fe80::bac7:5dff:fec8:50e ff02::1 ICMPv6 150 Router Advertisement from b8:c7:5d:c8:05:0e
Frame 3: 150 bytes on wire (1200 bits), 150 bytes captured (1200 bits) on interface 0
Ethernet II, Src: Apple_c8:05:0e (b8:c7:5d:c8:05:0e), Dst: IPv6mcast_01 (33:33:00:00:00:01)
Internet Protocol Version 6, Src: fe80::bac7:5dff:fec8:50e (fe80::bac7:5dff:fec8:50e), Dst: ff02::1 (ff02::1)
Internet Control Message Protocol v6
Type: Router Advertisement (134)
Code: 0
Checksum: 0x215a [correct]
Cur hop limit: 64
Flags: 0x48
Router lifetime (s): 1800
Reachable time (ms): 0
Retrans timer (ms): 0
ICMPv6 Option (Source link-layer address : b8:c7:5d:c8:05:0e)
ICMPv6 Option (Prefix information : 2601:xxxx:xxxx:47fc::/64)
ICMPv6 Option (Route Information : Medium 2601:xxxx:xxxx:47fc::/64)
ICMPv6 Option (Recursive DNS Server 2601:xxxx:xxxx:47fc:bac7:5dff:fec8:50e)
Sysctl accept_ra is enabled:
net.ipv6.conf.wlan1.accept_dad = 1
net.ipv6.conf.wlan1.accept_ra = 1
net.ipv6.conf.wlan1.accept_ra_defrtr = 0
net.ipv6.conf.wlan1.accept_ra_from_local = 0
net.ipv6.conf.wlan1.accept_ra_pinfo = 0
net.ipv6.conf.wlan1.accept_ra_rt_info_max_plen = 0
net.ipv6.conf.wlan1.accept_ra_rtr_pref = 0
net.ipv6.conf.wlan1.accept_redirects = 1
net.ipv6.conf.wlan1.accept_source_route = 0
net.ipv6.conf.wlan1.autoconf = 1
net.ipv6.conf.wlan1.dad_transmits = 1
net.ipv6.conf.wlan1.disable_ipv6 = 0
net.ipv6.conf.wlan1.force_mld_version = 0
net.ipv6.conf.wlan1.force_tllao = 0
net.ipv6.conf.wlan1.forwarding = 0
net.ipv6.conf.wlan1.hop_limit = 64
net.ipv6.conf.wlan1.max_addresses = 16
net.ipv6.conf.wlan1.max_desync_factor = 600
net.ipv6.conf.wlan1.mc_forwarding = 0
net.ipv6.conf.wlan1.mldv1_unsolicited_report_interval = 10000
net.ipv6.conf.wlan1.mldv2_unsolicited_report_interval = 1000
net.ipv6.conf.wlan1.mtu = 1500
net.ipv6.conf.wlan1.ndisc_notify = 0
net.ipv6.conf.wlan1.proxy_ndp = 0
net.ipv6.conf.wlan1.regen_max_retry = 3
net.ipv6.conf.wlan1.router_probe_interval = 60
net.ipv6.conf.wlan1.router_solicitation_delay = 1
net.ipv6.conf.wlan1.router_solicitation_interval = 4
net.ipv6.conf.wlan1.router_solicitations = 3
net.ipv6.conf.wlan1.suppress_frag_ndisc = 1
net.ipv6.conf.wlan1.temp_prefered_lft = 86400
net.ipv6.conf.wlan1.temp_valid_lft = 604800
net.ipv6.conf.wlan1.use_tempaddr = 2
net.ipv6.neigh.wlan1.anycast_delay = 100
net.ipv6.neigh.wlan1.app_solicit = 0
net.ipv6.neigh.wlan1.base_reachable_time_ms = 30000
net.ipv6.neigh.wlan1.delay_first_probe_time = 5
net.ipv6.neigh.wlan1.gc_stale_time = 60
net.ipv6.neigh.wlan1.locktime = 0
net.ipv6.neigh.wlan1.mcast_solicit = 3
net.ipv6.neigh.wlan1.proxy_delay = 80
net.ipv6.neigh.wlan1.proxy_qlen = 64
net.ipv6.neigh.wlan1.retrans_time_ms = 1000
net.ipv6.neigh.wlan1.ucast_solicit = 3
net.ipv6.neigh.wlan1.unres_qlen = 31
net.ipv6.neigh.wlan1.unres_qlen_bytes = 65536
IPv6 routing table:
$ route -6
Kernel IPv6 routing table
Destination Next Hop Flag Met Ref Use If
fe80::/64 :: U 256 0 0 wlan1
::/0 :: !n -1 1 11529 lo
::1/128 :: Un 0 7 32 lo
fe80::8e70:5aff:fed2:65bc/128 :: Un 0 1 0 lo
ff00::/8 :: U 256 1 0 wlan1
IPv6 neighbors:
$ ip -6 neigh
fe80::bac7:5dff:fec8:50e dev wlan1 lladdr b8:c7:5d:c8:05:0e router STALE
...and I'm able to ping link-local address of my residential gateway:
$ ping6 -I wlan1 fe80::bac7:5dff:fec8:50e
PING fe80::bac7:5dff:fec8:50e(fe80::bac7:5dff:fec8:50e) from fe80::8e70:5aff:fed2:65bc wlan1: 56 data bytes
64 bytes from fe80::bac7:5dff:fec8:50e: icmp_seq=2 ttl=64 time=277 ms
64 bytes from fe80::bac7:5dff:fec8:50e: icmp_seq=3 ttl=64 time=0.848 ms
64 bytes from fe80::bac7:5dff:fec8:50e: icmp_seq=4 ttl=64 time=13.4 ms
64 bytes from fe80::bac7:5dff:fec8:50e: icmp_seq=5 ttl=64 time=1.32 ms
64 bytes from fe80::bac7:5dff:fec8:50e: icmp_seq=6 ttl=64 time=0.934 ms
64 bytes from fe80::bac7:5dff:fec8:50e: icmp_seq=7 ttl=64 time=1.66 ms
^C
Any ideas on what it could be and how to fix that?
Thanks.
