33
Is there any command that prints only the name of the packages that apt-get autoremove selects? I'm creating a script that updates the kernel, removes the old kernel and the unnecessary packages (apt-get autoremove), but I want to print on the screen the list of packages that will be removed by apt-get autoremove, how can I do this?
kos
  • 41,268
Since as per your comment you want to list only the packages that are going to be removed:
apt-get --dry-run autoremove | grep -Po '^Remv \K[^ ]+'
grep command breakdown:
  • -P: Interprets the given pattern as a PCRE (Perl Compatible Regular Expression) pattern
  • -o: Prints only the matched string instead of the whole line
Regex breakdown:
  • ^: matches the start of the line
  • Remv: matches a Remv string
  • \K: excludes the previously matched substring from the matched string
  • [^ ]+: matches one or more characters not
$ apt-get --dry-run autoremove | grep -Po 'Remv \K[^ ]+'
libapache2-mod-php5
php5-readline
php5-cli
libonig2
libqdbm14
php5-json
php5-common
kos
  • 41,268
Actually you only need to filter the output of your
sudo apt-get autoremove --dry-run
command.
For instance you can do it with
sudo apt-get autoremove --dry-run  | head -n 5 | tail -n 1
A.B.
  • 92,125
No need for apt-get in modern apt versions. You can use
apt autoremove --dry-run
Abdull
  • 734
Using apt-patterns (see man 7 apt-patterns) one can simply do:
apt list '?garbage'
