When I was trying to mount my Windows hard disk I got this error:
Error mounting /dev/sda1 at /media/ubuntu/System: Command-line `mount -t "ntfs" -o "uhelper=udisks2,nodev,nosuid,uid=999,gid=999,dmask=0077,fmask=0177" "/dev/sda1" "/media/ubuntu/System"' exited with non-zero exit status 13: Corrupted file $UpCase
Failed to mount '/dev/sda1': Input/output error
NTFS is either inconsistent, or there is a hardware fault, or it's a
SoftRAID/FakeRAID hardware. In the first case run chkdsk /f on Windows
then reboot into Windows twice. The usage of the /f parameter is very
important! If the device is a SoftRAID/FakeRAID then first activate
it and mount a different device under the /dev/mapper/ directory, (e.g.
/dev/mapper/nvidia_eahaabcc1). Please see the 'dmraid' documentation
for more details.
(udisks-error-quark, 0)
What should I do?
Zanna
  • 72,312
mourad
Run:
 sudo ntfsfix /dev/sd(the location of the Windows filesystem)
For example if the partition is /dev/sdb1 that's what you would enter in the command. You can find the partition with lsblk or sudo fdisk -l
Zanna
  • 72,312
bio
  • 31
You should read (carefully) the error message:
for more details.
It shows a couple of things you could try:
run chkdsk /f on Windows then reboot into Windows twice
waltinator
  • 37,856
