Leading on from this question, I'm trying to write a bash script which will recurse two directories from the directory containing my subversion repositories, checking whether directories are repositories. There will be a mix of directories and repositories, and some repos hiding in those sub-dirs.
Any Subversion repos discovered should have their name printed to an output file, followed by the output of svnadmin verify.
I have the following snippet to check whether a directory is a repository:
svnlook info /path/to/repo >/dev/null
So I'm throwing away the svnlook output, a return code of 0 indicates that it is indeed a SVN repo. I could use this snippet, in an if statement to run svnadmin verify if 0 is returned.
I've tried:
find /dir/containing/repos -maxdepth 2 -type d -exec bash -c 'if [ "svnlook info {} >/dev/null" = 0 ] ;then ;echo "{}" >>output.txt ;svnadmin verify "{}" >>output.txt ;fi' \;
Though I get the following warning for each directory found:
bash: -c: -line 0: syntax error near unexpected token ';'
I think I'm trying to unnecessarily cram it all into one find command, which I'm getting wrong anyway. What would be the best way to structure this task?
Arronical
  • 20,241
You don't need ; after then in then ;echo "{}" >>output.txt.
Use :
then echo "{}" >>output.txt
Also note that rather than playing with {} use positional parameters of shell (i am not familiar with svn so relying upon your commands) :
find /dir/containing/repos -maxdepth 2 -type d -exec bash -c 'if svnlook info /path/to/repo >/dev/null ;then echo "$1" >>output.txt ;svnadmin verify "$1" >>output.txt ;fi' _ {} \;
  • if svnlook info /path/to/repo >/dev/null will run the command and redirect the STDOUT to /dev/null
  • If the svnlook info /path/to/repo command is successful (exit code 0), then echo "$1" >>output.txt ;svnadmin verify "$1" >>output.txt commands will be run
  • Here we are using the directory names {} as the fist argument ($1) to be processed by shell.
  • _ here is just a placeholder indicating positional parameter 0 as bash -c command starts considering any further argument after the command starting from 0. As _ is the zero-th argument, we can use {} as the first argument. Check man bash to get more idea.
heemayl
  • 93,925
