I'm new to Ubuntu and i have a problem and can't find an answer for it, so:
I'm using Windows + Ubuntu and i'm using a ext4 partition for storing my backup, BUT every time when i need to do some changes on this partition i need to do at as a super user and okay this is not a problem, but when the default backup program need do save the backup there the system is show me and error. Can you help me how to fix that ?
Asked
Active
Viewed 71 times
Maythux
- 87,123
Bogdan Bogdanov
- 113
Changing permissions in fstab in order to allow writing for this partition, or just change permissions for backup folder
Try to add your external Hdd to fstab so that it's automounted while booting
Get the UUID
Run the command:
sudo blkid
Then open /etc/fsatb:
sudo gedit /etc/fstab
Now add the line to the bottom of /etc/fsatb:
UUID=UUID /mounting-point ext4 defaults 0 2
Replace UUID with result of your UUID of /dev/sdX
Replace /mounting-point with path to mount the partition on
Reaplce ext4 with your partition filesystem type
