93
How to install Arial font in Ubuntu?
I found many ways to install fonts in Ubuntu but I didn't find any proper way or method to install (particularly) Arial fonts in Ubuntu.
MERose
  • 437
  • 24
Yuvaraj V
  • 1,806
6 Answers6
151
Simply run
sudo apt install ttf-mscorefonts-installer
sudo fc-cache -f
in a terminal.
After that, check with
fc-match Arial
A.B.
  • 92,125
21
Since the ttf-mscorefonts-installer mechanism mentioned in the accepted answer is still broken in Ubuntu 18.04 and I could not find a suitable mirror server for it to fix it, I propose to use this manual mechanism instead to install the very same fonts:
  1. Install cabextract, a tool needed to unpack self-extracting .exe archives:
    sudo apt install cabextract
  2. Download the font package provided via this page (also note the EULA there):
    wget https://www.freedesktop.org/software/fontconfig/webfonts/webfonts.tar.gz
  3. Unpack, twice:
    tar -xzf webfonts.tar.gz
    cd msfonts/
    cabextract *.exe
  4. Move the fonts to your user's directory for installing additional fonts:
    cp *.ttf *.TTF ~/.local/share/fonts/
  5. Restart the software in which you want to use the fonts, and they should be ready to use.
tanius
  • 6,610
  • 42
  • 52
18
I have been getting LiberationSans-Regular.ttf: "Liberation Sans" "Regular" for sudo fc-match Arial
So I tried following to make it work :
1) Create directory to download fonts to: sudo mkdir ~/ms-fonts/
2) cd ~/ms-fonts/
3) Download fonts manually :
wget http://downloads.sourceforge.net/corefonts/andale32.exe
wget http://downloads.sourceforge.net/corefonts/arial32.exe
wget http://downloads.sourceforge.net/corefonts/arialb32.exe
wget http://downloads.sourceforge.net/corefonts/comic32.exe
wget http://downloads.sourceforge.net/corefonts/courie32.exe
wget http://downloads.sourceforge.net/corefonts/georgi32.exe
wget http://downloads.sourceforge.net/corefonts/impact32.exe
wget http://downloads.sourceforge.net/corefonts/times32.exe
wget http://downloads.sourceforge.net/corefonts/trebuc32.exe
wget http://downloads.sourceforge.net/corefonts/verdan32.exe
wget http://downloads.sourceforge.net/corefonts/webdin32.exe
4) sudo dpkg-reconfigure ttf-mscorefonts-installer and follow instructions. When asked, use full path to directory where fonts were downloaded i.e. /home/root2/ms-fonts/
5) sudo fc-cache
6) Check if installation is done successfully or not : sudo fc-match Arial
Hope this helps.
terdon
  • 104,119
Swapnil
  • 181
10
I search for a solution for similar problems when preparing the docker file.
When you install fonts with the same command:
DEBIAN_FRONTEND="noninteractive" apt-get -y ttf-mscorefonts-installer
A license agreement is not applied and Arial and other fonts are not installed!
You can use this solution:
echo "ttf-mscorefonts-installer msttcorefonts/accepted-mscorefonts-eula select true" | debconf-set-selections
apt-get install -y ttf-mscorefonts-installer
And you can check the result with the command:
fc-match Arial
barsmaga
  • 126
The ttf-mscorefonts package mentioned in the other answers contains a very limited selection of fonts, and rather outdated versions of them.
To get a better selection of up-to-date fonts, you can instead rip them from a Windows installation. Microsoft itself provides free virtual machine images of Win 11, ostensibly for "testing sites on MS Edge", which you can use for this.
Distributing fonts obtained this way is probably illegal, but using them yourself may or may not be be fine.
  1. Get an image here, select "VirtualBox".
    The filenames below will be different depending on the VM image version.
  2. unzip WinDev2301Eval.VirtualBox.zip - this might take a while
  3. tar -xf 'WinDev2301Eval.ova' - this might take a while
  4. sudo apt install libguestfs-tools
    sudo mkdir /mnt/foo
    sudo guestmount -a 'WinDev2301Eval-disk001.vmdk' -i --ro /mnt/foo
    sudo cp -r /mnt/foo/Windows/Fonts/ .
    sudo umount /mnt/foo
    sudo rm -r /mnt/foo
    sudo mv Fonts WindowsFonts
Now you should have a WindowsFonts directory in the current directory, containing all the fonts you want.
  • To install them for all users, copy it to /usr/local/share/fonts.
  • To install it just for yourself, run sudo chown -R "$USER:$USER" WindowsFonts to change the owner to yourself, then copy the directory to ~/.local/share/fonts/.
Do following steps:
  1. Open software manager if its mint or Ubuntu software center if you are using Ubuntu
  2. Search for ttf-mscorefonts
  3. Install it
d a i s y
  • 5,551
viper
  • 173
