I am unable to install wkhtmltopdf on Ubuntu 14.4. I downloaded from wkhtmltopdf Linux (Ubuntu Trusty) 64 bit. I ran the following command:
sudo dpkg -i wkhtmltox-0.12.2.1_linux-trusty-amd64.deb
Here's the log
(Reading database ... 61662 files and directories currently installed.)
Preparing to unpack wkhtmltox-0.12.2.1_linux-trusty-amd64.deb ...
Unpacking wkhtmltox (0.12.2.1) over (0.12.2.1) ...
dpkg: dependency problems prevent configuration of wkhtmltox:
 wkhtmltox depends on fontconfig; however:
  Package fontconfig is not installed.
 wkhtmltox depends on libjpeg-turbo8; however:
  Package libjpeg-turbo8 is not installed.
 wkhtmltox depends on xfonts-base; however:
  Package xfonts-base is not installed.
 wkhtmltox depends on xfonts-75dpi; however:
  Package xfonts-75dpi is not installed.
dpkg: error processing package wkhtmltox (--install):
 dependency problems - leaving unconfigured
Processing triggers for man-db (2.6.7.1-1) ...
 wkhtmltox
I searched but could not find anything specific. What am I missing here?
bitkot
  • 223
first of all, if you don't care about version, you can install the package founded in the official Ubuntu repos:
sudo apt-get install wkhtmltopdf
But if you want to install your specific version above(0.12.2) you should resolve the package dependencies.
first try to run the command:
sudo apt-get install -f
If this solves it then ok else you have to install each dependency yourself.
From above you can install each dependency yourself
sudo apt-get install fontconfig
sudo apt-get install libjpeg-turbo8
sudo apt-get install xfonts-base
sudo apt-get install xfonts-75dpi
But an easier solution is to use gdebi.
sudo apt-get install gdebi
then you can use it to resolve dependencies:
sudo gdebi wkhtmltox-0.12.2.1_linux-trusty-amd64.deb
Maythux
  • 87,123
