I have been working on setting up some symbolic links so that I can easily access directories and files on another internal hard drive. When I create the links they work well, but every time that I restart the links are lost. Is there a better way to use links or refresh them?
I am currently creating links like this
ln -s /media/UserName/DiskName
I am running ubuntu 15.04 64-bit
The reason is quite clear. You did not set mounting rules for this disk in /etc/fstab/.
When system starts, the disk is not mounted.
Just add a line to /etc/fstab for a permanent rule and the problem will be solved.
This is a guide.
Pilot6
  • 92,041
