I have pc and laptop and I am using ubuntu 14.04 beside windows xp sp3 on both devices. I tried to share folders between them .
  1. I installed Samba .
  2. Set a user and password .
  3. Set folders as shared (on ntfs partitions ) on both devices.
  4. Tried to get into Workgroup network but keeping ask password and do not response when I entered the password that I set on samba or user password.
I can get into shared files on windows using Ubuntu only but not vice versa. I tried Ubuntu-Ubuntu from desktop keep asking basswd and from laptop do nothing not working with me Any help please.
Tarek
  • 378
While I am pretty sure that any filesystem can be mounted in a Linux operating system (including NTFS, FAT32, FAT16), Windows does not see Linux filesystems (e2fs, e3fs, reiserfs, etc). A possible solution could be to make a folder on the Windows system and save files to be shared to that folder while in the Linux system. This actually makes viewing 'shared' files viewable (workable? editable?) in both systems.
                 Hope this helps, Craig
Craig
  • 127
you did use smbpassword to set the user password right? The user password and the samba password are different in linux
To create initially sudo smbpasswd -a nameuser
or if added remove -a to change passwOrd
in /etc/samba/smb.conf set workgroup encrypt password to. True Passdb backend tdbsam
Then define an entry at the end [Data] comment = data path = /somewhere/data guest ok = no browseable = yes writeable = yes users = seb frank
Run smbpassword -a to set password for seb and franck, after creating local user
When prompted by windows enter the credentials.
altagir
  • 259
