I am trying to get Openvpn run inside a LXD/LXC container, and redirect traffic coming to the container to the VPN.
The purpose is to replace a fully fledged VM that does exactly that (and toy with LXD :-)
I managed to get an IP from my main DHCP server, set up the iptables rules for masquerading / forwarding the traffic, but when I try to launch openvpn, it is blocked by the lack of (access to) /dev/net/tun device.
I came accross this post on ServerFault https://serverfault.com/questions/429461/no-tun-device-in-lxc-guest-for-openvpn, but it does not seem to work with current version of LXC and/or LXD managing the configuration...
EDIT: I tried using this incantation, but it did not succeed:
lxc config set mycontainer raw.lxc 'lxc.cgroup.devices.allow = c 10:200 rwm'
EDIT2: tried lxc config device add mycontainer tun unix-char path=/dev/net/tun major=10 minor=200 but on next stop/start, I got
error: Failed configuring device tun: Not implemented
Now I can't even lxc config device remove mycontainer tun as it throws the same Not implemented error. Container seems to be lost...
