so I have a very depressing problem actually. I'm not sure what I have exactly done, but I'm pretty sure its within the limits of removing the Windows boot loader partition that remained after I completed wiped windows off my computer and replaced it with ubuntu.
After that, I accessed the BIOS, made it so I was able to boot from usb then proceeded to boot ubuntu from my usb drive in an attempt to add the free space that was available after the removal of that partition to my ubuntu partition (sda5).
Done all that, I remove the usb drive, reboot, and that's when I get an error saying I should go into advanced options in my BIOS and choose the correct boot device as it couldn't detect any from which it could boot from, I spent the last hour going through this forum since nothing could work and solve the problem for me. None of that worked, and Ubuntu completely disappeared from the boot menu options in the BIOS, I checked in GParted, the Ubuntu partition is STILL THERE with ALL the data and content, it's just, there is no way I could find it and use it as a boot option to boot from it, there's no trace of it in the BIOS.
I tried some of the answers I found here if not all of the available ones relating to this issue, I tried mounting it, I even got the partition I deleted back and still no luck, the only way I could now boot Ubuntu is from the usb drive, it wouldn't boot anything apart from something from a usb drive.
Have you guys ever faced such problem? Any answers relating to this issue would be greatly appreciated, as I don't want to re-install Ubuntu as I still have a lot of data/content on that Ubuntu partition and there's no way I could retrieve it after the installation.
It's an ASUS motherboard by the way if you're wondering. Thank you for your time!
Oh and, I almost forgot, when I checked on GParted, instead of ext4 it said efi for the Ubuntu partition, it's still that way, I tried changing it to ext4 and put '/' as the mount point, it changes but once I check again I find it hadn't changed, which is frankly weird and confusing.
