I really tried alot to install ubuntu alongside with my preinstalled window 7. also, read many articles posted on internet regarding dual window installation. But nothing is working for me. So, I need to know the installation procedure for the same.
I made bootable pendrive of ubuntu 14.04 with the help of rufus software by choosing GPT partition scheme for UEFI. Also, i deleted by recovery disk and shrinked volume C. Then, restarted my computer and boot with ubuntu by hitting F11. I clicked on install ubuntu, chose language and select location. Then, setup asked about battery and space. After this I pressed continue, then i waited for 10-15 min but nothing happens further. I tried a lot but nothing is happening beyond this step.
Pilot6
  • 92,041
After reading the comments it seems to me that there is a disconnect in understanding. Follow the steps below which should result in a clean install.
  1. Create your bootable USB using Rufus
  2. Reboot the pc, and boot the USB drive
  3. Ensure that you have a wired internet connection
  4. Uncheck third party apps and software (as this slows down the install greatly)
  5. Allow time - The install for me in the past has taken almost 2 hours, don't be in a rush. Leave the room and come back later in the day or evening.
The biggest issue is your internet it must be hardwired, especially if you are choosing to install third party apps and software. Also be patient during the install.
Joe
  • 149
I've had problems with initially installing Ubuntu on my Toshiba, but it is possible.
Try disabling the secure boot option in your BIOS, and if that doesn't work try switching to CSM boot mode, that should work.
