Just installed Lubuntu 15.04 on an Acer Aspire 5100, the broadcom router is the BCM4311 model. I have tried a few different fixes but none of them seem to work. I have a few other Acer laptops that I will be installing Lubuntu 15.04 on as well (Aspire & Travel Mate) so I am hoping to find the right fix for the broadcom problem. Thanks :)
ETA: Terminal results of this command lspci -knn | grep 'Eth|Net' -EA2
02:00.0 Network controller [0280]: Broadcom Corporation BCM4311 802.11b/g WLAN [14e4:4311] (rev 01)
  Subsystem: AMBIT Microsystem Corp. Device [1468:0422]
  Kernel driver in use: wl
06:01.0 Ethernet controller [0200]: Realtek Semiconductor Co., Ltd. RTL-8100/8101L/8139 PCI Fast Ethernet Adapter [10ec:8139] (rev 10)
  Subsystem: Acer Incorporated [ALI] Device [1025:009f]
  Kernel driver in use: 8139too
ETA: got the wireless to work finally but when I reboot it will try to connect to the ethernet 1st (I then have to right click on the network connection icon to tell it to connect to the wireless) any way to force it to try the wireless 1st? I have already removed the ethernet connection from the list of connections. Thanks
E: Unable to lock the administration directory (/var/lib/dpkg/), is another process using it?
This usually means that another process, typically Update Manager, Software Center or Synaptic is open and has a hold on /var/log/dpkg. Please close whichever it is. Then in a terminal and with a temporary working internet connection, do:
sudo apt-get purge bcmwl-kernel-source
If it is not removed because it isn't installed, that's fine, just continue:
sudo apt-get install firmware-b43-installer
Reboot and your wireless should now be working.
chili555
  • 61,330
