I am trying to install Octave-4.0.0 from source following the instructions from the wiki page. I have installed every single dependency (optional too) mentioned on that page. In the configuration step I used
./configure CPPFLAGS=-I/usr/include/hdf5/serial \
            LDFLAGS=-L/usr/lib/$(dpkg-architecture -qDEB_HOST_MULTIARCH)/hdf5/serial
as given there to avoid potential HDF5 library related problems. Doing this, I got (initially I was getting JAVA_HOME warning, which I then fixed):
configure: WARNING: Include file <jni.h> not found.  Octave will not be able to call Java methods.
configure:
configure: NOTE: Libraries or auxiliary programs may be skipped if they are
configure: NOTE: not found OR if they are missing required features on your
configure: NOTE: system.
Thereafter, to fix this, I tried using how to add jni.h and adding libraries to ./configure path. But, if I follow that configure command with
./configure CPPFLAGS=-I/usr/lib/jvm/java-7-openjdk-amd64/include
or even use both the CPPFLAGS settings together (that is, in the same ./configure line), I get this:
configure: WARNING: HDF5 library not found.  Octave will not be able to save or load HDF5 data files.
configure: WARNING: Include file jni.h not found.  Octave will not be able to call Java methods.
configure:
How should I pass these warnings and install Octave-4.0.0 gracefully (target: image processing)?
devautor
  • 111
If you try to define multiple CPPFLAGS variables on the command line, only the last one will apply. Instead, you should be able to combine both include directives into a single variable as a quoted string:
CPPFLAGS="-I/usr/include/hdf5/serial -I/usr/lib/jvm/java-7-openjdk-amd64/include"
e.g.
./configure \
  CPPFLAGS="-I/usr/include/hdf5/serial -I/usr/lib/jvm/java-7-openjdk-amd64/include" \
steeldriver
  • 142,475
